Question about Vtech CS5121-3 Trio Cordless Phone
Phone line is always busy when someone calls
I never know the phone was ringing since it doesn't on my end even though I have call waiting. Went through the trouble shooting ideas in the users manuel with no succes. Mainly checking connections, wiring, unpluggin all, etc. A few months ago, the phone was actually ringing for the people calling in, but it never really rang on my end, went to the answering machine, etc., but after following manufacturer's manuel, I got it working again. No luck so far with this new problem. Have a "main" phone with an answering machine and 2 Aux. phones ties to it that only require an elec. connection. Phone is approx. 1 1/2 years old and I would rather not replace it, but need a phone that works.
2 Suggested Answers
  • 264 Answers
SOURCE: Manual
I have provided a link below where you can find the manual for your phone.
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=364
I hope that should help you fix the issue you are facing. Will wait for the rating to know the result.
Thanks
Sammy
Posted on Dec 06, 2007
Not receiving all incoming calls. Callers get "All circuits are busy" or "This number is no longer in service" when they call. Some calls do come through. We can call out.
My phone is from the same Panasonic line.
Since you can call out it seems to me that it is the phone company's error message..
"All circuits are busy" and "this number is no longer in service" are telephone company error messages.
Did you have this problem with other phones? Maybe you can take the phone to a friend's for family's home and try it there. If the phone is okay, call Telus back and let them know that the phone tested okay and ask what they are going to do to fix the problem.
Seems to me that their circuits are overloaded and they are blaming your phone because it is something they can't repair. Only fixed by them spending $$ to increase/ expand band width.
May 11, 2016 | Panasonic KX-TGEA20 Additional Digital...
I am using a Nortel T7208/T7316 sets (BCM 450 PBX) system, and I want to program a phone to ring when someone calls the main line. Most of our phones only ring when you type the extension internally. I...
The phone must be programmed with the target line assigned to the number you wish to have ring at that phone. This can be done with the BCM Element Manager interface. If your BCM450 is running version 6, I think this can even be done directly from the phone, but I'm not sure of that process.
Nov 09, 2012 | Nortel Business Series Terminal T7208 -...
If I get this AT&T 1739 answering machine will it retreive messages when I am on the phone with someone else, also can I record my own message on it for my business
Without call waiting or a second line, callers will get a busy signal if you're already on a call. This happens at the switchboard; it doesn't matter what type of answering machine you have because the second call doesn't get that far.
You can record your own message on the 1739 but, as mentioned above, if you're already on a call then the second call never gets that far.
Mar 08, 2012 | AT&T ATT1739 Digital Answering Machine
In NBX 100 3COM phone system cannot take calls from out side as user busy signal comes. There are 10 channels. but none of them are busy. When checking the cause code the 17 code is visible. This happened...
I know this is old but maybe it can help someone else.
The line cards are "hot swappable and don't always reset with a reboot (especially a Digital Line card) you should try to re-seat the Line card after the system has booted up. This is done by unscrewing the black knobs at each end and then sliding the card out about an inch. Wait about 10 seconds and plug it back in. It takes about 2 minutes for the card to boot and synch with the phone company. Try your call again. If it's still not working after about 5 minutes, check the card in the phone system and make sure the channels are idle. If they are, call the phone company.
Aug 06, 2011 | 3Com NBX 3102 IP Phone
KX-TG6441 Phone shows "in
You have a short circuit somewhere...start by unplugging the phone from the phone jack in the wall. Wait 15 minutes or so for the line to clear, then try calling your number from another phone. If you hear a ring, the problem is either in your phone internally, or the cord connecting the phone to the jack (which can be replaced at Radio Shack or similar). BTW, are there other phones in the house? If so, do the same with them one at a time to isolate the problem. If disconnecting all phones (and waiting) doesn't clear the problem you have a short elsewhere, such as house wiring, or the phone jacks. But a busy signal ALWAYS indicates a short... good luck.
May 31, 2011 | Panasonic Lands Phones
How does the call waiting work on the phone? If I am already on the phone I cannot answer the other line even though I hear it beeping
hi, the call waiting is just there for you to know that someone else is trying to reach you...but its not possible for you to pick two calls at a time...you can only answer one..so, if someone important is trying to reach you while you are on call, the call waiting will let you know..it is now left to you to decide if you want to answer it or not.
Jul 25, 2010 | HTC HD2 Smartphone
Hello I have a KX t7730 with 4 lines installed in it. the problem is that if person X phones and i am on the line speaking with person Y, than person X go's into voice mail instead of being "dragged " to a...
My office phone is set to Call Forward No Answer to Voice Mail.
I'm guessing that you are learning the difference between the TA series and the TAW or TDA series. Call waiting is programmed from a CW code dialed into the intercom (ie 7311 or *7311) and call forwarding to VM is programmed by a 71x or 710x or *710x command. In a TD TDA or TAW system, you get CF BUSY, CF NO ANSWER, or CF busy/NA.
In a TA you only get CF ALL, or CF Busy/NA.
So, if someone rings your phone while it's busy, there is no indication, just an immediate forward if that feature is set.
Carl
Dec 07, 2009 | Panasonic KX-T7730 Corded Phone
Trouble with call forwarding to our multiple lines & voicemail
It's not and they're idiots. The hunt sequence you describe CF-No answer is part of their arrangement, probably Centrex/Centranet.
This is one of the sloppiest setups they can possibly give you, but it relates to destinations for CF busy and CF no answer. Get someone who has a clue and tell them to adjust the time on the No Answer part, or, better yet, give you something that really works.
Carl
Jun 01, 2009 | Vodavi 30-BUTTONVODAV XTS Telephone
Call Waiting
THere are two answers to you question, depending on certain options and conditions.
First, where is the voice mail and where is the call waiting coming from?
1. If Voice Mail (VM) is located in the central office and you have a destination for call forward BUSY/NO ANSWER it will go to CO VM.
2. If Voice Mail on premise (Partner Mail), and you have CF BUSY/NO ANSWER set on your phone, it will go to voice mail....IF the call waiting is coming from another line. The CF and ring count is set in Partner system programming.
3. If you have call waiting coming on the same phone line and don't have CO VM, then you have no voice mail.
My CO codes for VM are 72# for Call Forwarding and *92 for CF Busy.
As Always, YMMV
Carl
Sep 14, 2008 | Avaya Partner 34B Corded Phone
Vintage phones cannot dial out
Any standard phone should work, even phones made in 1800's should still work on a standard phone line.
I'm not sure what phone you have. The one listed in the question "M7310" is a business system phone and will ONLY work on the Nortel business phone system.
If you have standard home phones, my only suggestion (using the information supplied) is to check if the Tone/Pulse switch is set to tone... even though both should work.
Do you have phone service through a cable line?
May 28, 2008 | NorStar M7310 Phone
Vtech CS5121-3 Trio Cordless Phone Logo
402 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
