Tumbler wont spin during spin cycle
The main tumbler does not spin at all only the agitator in the tumbler moves. I checked under the washing machine and did not see any loose/broken belts.
  • yadayada
    yadayada May 11, 2010
    does the drive motor work?
    Problem Solver:
  • 9 Answers
Have the motor checked. It may stuck up and needs rewind.
Posted on Jul 22, 2009
Knocking during wash and spin cycle
I woulds let a repairman look at your machine. Your rubber dampers are broken and your machine will shake itself to bits if you don't address this problem.
Mar 07, 2014 | Computers & Internet
Washer tumbler does not spin in final stage
hi sounds like the gearbox has slipped a cog and stuck that will cause the belt to burn
Nov 01, 2011 | Frigidaire FEX831CS Top Load Stacked...
Dark stains occuring in a pattern of dots on garments (pattern
operate one quick cycle with not load with hot water and detergent to clean the drum
Mar 18, 2010 | Frigidaire 14 Cycle Tumble Action Washer
During the spin cycle, the agitator makes a knocking/clicking sounds. Works good other then that.
If your machine type is a FAV6800AW or FAV9800AW the tumblers or agitator should no rotate in spin cycle maybe a 1/8 turn and no more at the start of spin cycle . If your machine is one of the above machine types maybe you have coins or something under the tumblers. You can remove the tumblers by removing the plastic tumbler caps and with a #20 torx driver. See page 37 for tumbler removal. If your machine type is not the above please disregard my post.
The Service Manual for reference. Sears Parts Direct for reference.
I have another thought but if you could confirm the machine model number that would be helpful. So many folks post non FAV6800AW machine types in this forum.
Thank you… Rich
Nov 01, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine GLWS1649ASO wont spin on spin cycle. motor and pulley turn, but belt doesn't move. Is it the belt?
no it will not be the belt more so it will be a bad transmission.or something stuck under the agitator i have seen drill bits and keys get stuck under the agitator and cause the transmission to stop
remover the agitator first and check it is there is nothing there the transmission needs to be replaced
Oct 02, 2009 | Frigidaire GLWS1649A Top Load Washer
My Neptune is very loud during agitation. Any
sorry about that to me if also very loud on the spin cyc and is a front load the tub bearing and then your talking a major overhaul with high cost involved
Aug 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Banging tumbler during spin cycle
Be certain that nothing got under the rubber skirt, pull it back and look /feel under it .
inside the tub are the large wiper arms solid and not come loose.
open the top access panel (3 screws in top rear )
and open the bottom access Panel (3 screws in bottom front)
Dissconnect power .
Look at the springs and arms that attach to the tub are they secure.
is the large stone concreate slabs secure.
move all these items and push at them all secure?
you can run it while open but the bottom has a switch on front right that has to be closed.
look watch listen.
Feb 03, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Nov 29, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
