REPLACING A/C EVAPORTOR 1995 GMC TRUCK I NEED TO KNOW HOW TO TAKE APART THE DASH AND INSTALL THE EVAPORATOR. THEN INSTALL THE DRYER.
  • 3,600 Answers
I can help you with this but it is a good-sized job. You have other things you must do as well. First I need to know why you are replacing the evaporator is it leaking or plugged? The reason I ask is if it is plugged then you have contamination coming from the hose or the compressor which means you will have to replace the rubber hoses and or blow out the old hoses and see if anything comes out of it. And if your doing it because it is not cooling then you need to first pull the Orifice tube to see if it is plugged, because if the orifice tube is plugged it will cause the AC not to get cold, and goes directly to the Evaporator. To check it first unhook the nut on the line going to the dryer receiver the line will have a slightly larger tube on one side when you remove the nut pull the line apart and with a pair of needle nose pliers pull the plastic tab out of the enlarged tube. When you pull it out you will see a small screen notice it if has anything blocking it. Like rubber or metal, this is important because it will tell you what you need to replace depending on the contamination on the screen. Just to let you know it's against the law to dump the refrigerant out into the atmosphere it is to be vacuumed out by a shop so that it can be filtered and reused. Next using two wrenches to back up the one side of the line on the loosen the nut and unhook the line, any open lines tape them shut so they don't get air in the system, the moisture from the air will cause an acid when mixed with the refrigerant and will destroy metal and hoses. Now disconnect the clamp that holds the receiver/dryer on and empty the oil out of the dryer, see if it is clean, if not you will have to drain the oil out of the compressor as well as back flush all the lines. You can buy back flush for AC systems from most auto parts stores. Next disconnect the low-pressure side switch from the dryer. And remove it, I recommend replacing the switch as they leak with time
Now to remove the Evaporator if you are sure it needs replacing you will have to take the bolts out of the plastic housing and on some rigs it's inside the cab and others it's in the engine compartment, if it's outside in the engine compartment you will have to remove the twelve screws that hold the plastic part on, at this time disconnect the return line from the Evaporator, if the evaporator is on the inside then you must pull apart the plastic housing that the evaporator is in once you have the case half off be careful to not damage the gasket or the blend door motor or hose. Once you have it loose remove the rubber grommets that hold the pipes on to the firewall with a flat tipped screwdriver slightly oil the lines with the oil you drained out of the receiver dryer. Then work off the grommets, as you will need them again. Then install the new evaporator and install the new grommets, make sure you tape the ends so that when pushing the evaporator in place that you do not get any crude in the evaporator.
Next remove the compressor and dump out the oil in the compressor and measure it so you will know how much to put back in. use the spray can back flush to clean the compressor out. Then reinstall compressor next buy a set of o rings and a orifice tube and 10 to 12 ounces oil compressor oil or refrigerant oil, if you have R134A get Pag oil, you do not want to mix oils so get the one for R134A. Now pour about 6 ounces into the dryer and install the dryer into its holding clamp remove any old o-rings and use a q-tip to oil the rings replace the o-rings and bolt it back together. Put a tiny amount of oil on the orifice tube slide the tube into it's cavity making sure the flat spot is flush to the wall and be sure to install it with the flat side towards the condenser, Replace the o-ring by the tube and lightly oil it. Be sure to flush out the condenser before rebooking lines. When you pulled out the orifice tube if you found rubber in the screen then replace any rubber hoses that are used so it will not plug up again, when the compressor is running in max mode the pressure will go to as high as 325 PSI and the temperature will reach as high as 125 F. or more so do not chance using an old hose if you find rubber in the screen. Next add three ounces of oil into the compressor. And replace the o-rings to the compressor there are several types one bolt holds both lines on or two screw on types hoses. Replace the o-rings and lightly oil, the old o-rings will look flat and square cut but they are not they get that way over time the rings must fit in the grove and stick part way out to seal, just for your information you might think they gave you the wrong o-ring kit. Now remove the tape from the evaporator install o-rings and reconnect the lines install the low-pressure switch in the receiver dryer and reconnect the electrical lines. Now take it to a shop and have them vacuum it down and add the refrigerant, unless you have your own evacuation machine. There are two type systems add on after market and then there is factory you did not say which that is why I can’t be more specific about the evaporator as it is mounted different if it’s after market, and sometimes people have the dealer add them on when they buy them and even thought the dealer installs it it’s still considered after market. Do not add oil tothe evpaerator or the condensor and replace the Compressor belt at the same time. good luck hope this helps.
Posted on Jul 22, 2009
I have a 1995 GMC Vandura 2500 custom van. i need to know location and how to replace wiper motor
Make sure that's what you need because it's not a fun job.The wiper motor is under the dash above the gas pedal.Way up under the dash.Partial and/or full dash removal may be necessary.It depends on your skill level and determination! One heck of a great van to own!
Apr 28, 2017 | GMC Cars & Trucks
Has hot air coming from under dash with nothing on
Harold, one of the vent door actuators is probably stuck holding heater doors open, or the duct work may have come apart under dash.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 11, 2016 | 1995 GMC Jimmy
How to replace evaporator of air conditioning?
pull the dash apart not fun plan a whole week end if your new to that kind of work
May 30, 2012 | 1995 Dodge Caravan
Directions on how to change evaportor core on 1994 gmc sierra truck , thank you
the big black plastic box on the right side of the truck under the hood is the place where the evaporator is located. evacuate the a/c system,disconnect the hoses going to the black box,then remove the evap housing(the black box) from the firewall. be careful when separating the box because the plastic is brittle and it cracks and breaks easily. once apart the evaporator can be removed.
Jul 21, 2011 | GMC Sierra 1500 Cars & Trucks
How do you replace the evaporator core for the a/c? on a 1994 gmc p/u truck, I've already have the dash out having promblems removing the duct work, what's next? or is there a maunal that will show me.
your instructions are on how to replace the condenser on a 1994 gmc sierra but the title says it is the directions for replacing an evaporator. please correct your title.
Aug 08, 2010 | 1994 GMC Sierra
Ac works fine for about a week then shows low refrigerat level and compressor off-- no sign of leaking . mechanic checjed dryer. compressor replaced sensor on inside of frame and checked control in dash
Sounds like you have a leak. Some leaks are not that easy to find. I would inject some U.V. dye in the system and check for leaks with a high intensity black light, this process has never failed me, Also you might have a leak in the evaporator which would be hard to see without taking the housing apart, which in most cases means removing the dash
Nov 28, 2009 | 1995 Cadillac DeVille
I have a ac leak in the dashboard the part is a evaportor jeep cheeorkee 2001 larado guy is trying to charge 800.00 does that sound right??
wow that is cheap last time I took apart a dash for one of those it was well over 800 dollars plus the freon.
Jul 10, 2009 | 2001 Jeep Cherokee
How to replace a evaportor core in a 1996 Town & Country
the only way to replace evaporator core is by removing dash pannel, its very hard, i to make this work 2 years ago and i dont have to know about this again, i recomend you go to a good place to do, good look
Jul 05, 2009 | 1996 Chrysler Town & Country
2000 BMW 323ci-Evaporator core replacement
Yes I know how to replace the evaporator core. It involves getting into the passenger side dash because it is pretty much where the heater core is for the heating system
Jun 11, 2009 | 1998 GMC Jimmy
Heating & Cooling Logo
207 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
