Replacement belts figure large in the repairman's armoury so most supplier's catalogues contain a popular selection of types.
I suggest you google your requirements and you should find lots of results to investigate or ask a local repair shop.
Belts are usually supplied by size and cross section. Even when the old belt is available to help identify the requirement a certain amount of guesswork is needed as the old belt will have stretched. Some cassette belts will do the job stretched just a little and some need stretching quite a bit. If the length isn't known it can mean a certain amount of trial and error and the purchase of two or three belts before the correct one is found.
I used a rubber band on mine. Works perfectly!
