Question about KitchenAid Architect S Series II KUCS03FTSS Fully Integrated Trash Compacto
KitchenAid compactor won't solid pack
The compactor goes through it's pack cycle and returns to the top but won't stop and solid pack like it used to. I do make sure that it is mostly full before turning on the solid pack feature.
  • 1751 Answers
SOURCE: I have a KitchenAid Trash Compactor Model
Hi
you better replace the unit
is not relibly try fixxing it
Posted on Nov 26, 2010
SOURCE: Trash Compactor Problem
Had a similar problem with mine. I took it apart and found that the nut that is on the bottom end of the ram screw was loose. I tightened it and it fixed the problem. That was about a month ago. Now it is doing it again. I'm going to tighten it again this weekend and apply Loc-tite to the threads.
To get to the nut, you have to lay the compactor on its side and remove the plate from the bottom. You'll see a chain that goes around the motor sprocket and both ram screws. You need to tighten the nuts on the ram screws.
Hope this helps.
Steve
Posted on Jan 17, 2008
SOURCE: My KitchenAid trash compactor model KUCP021RBL1: cycle does't end
Most likely the motorwindings have been overheated after staying to long time in down position and trying to get up.
If there is a Emerson motor in your compactor than you will not find anything wrong most likely it is the winding of the motor, we have had this two times, changed the motor and the problem is solved.
Kind regards,
Paul
Netherlands
Posted on Mar 04, 2009
SOURCE: Kitchenaid compactor KUCS03FTSS makes banging
I bought a Kitchen Aid trash compactor the end of Sept/2008. By July/2010 I have spent $528 on having it fixed! It only cost $623 new so I called Whirlpool customer satisfaction line where after waiting 15 minutes was told that "With all due respsect mam, Whirlpool owes you nothing" Then " as a courtesy" they offered me 50% off an $80 part that I still need to pay $60 in labor to install! So,that would be an additional $100 on an appliance that has been trouble from the get go...I have had numerous compactors before this brand and have never had any trouble...Do NOT buy anything made by Whirlpool as they have apparently, a NO customer satisfaction policy.
Posted on Jul 16, 2010
  • 142 Answers
SOURCE: Kitchenaid trash compactor bought in
at the top, above the ram, there are two switches. One is the reversing switch (should have 4 wires), the other is the stop switch (2 wires). I suspect that the switch arm is bent, due to what you just described, and fails to activate the switch to stop the motor when the ram is at the top position.
Posted on May 24, 2011
I have a kitchenaide compactor. The ram is down and the door is open completely.
Sounds to me like you may need to turn off the breaker and hope it resets to the open position. or if you can see the plug you can unplug it.
Aug 24, 2014 | KitchenAid Architect S Series II...
Compactor wont shut off. is all the way up
Check the upper limit switch, you may only have an issue with the contact arm to sense the rams position. Look there first before buying anything. Good Luck
Jul 20, 2014 | KitchenAid P Series Trash Compactor -...
Trash Compactor Thumps
I would guess there is a limit switch that tells the machine to stop once the compactor has retracted.
May 04, 2013 | Kitchen Appliances - Others
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
Kitchenaid trash compactor bought in 2000; no model/serial number found. Compactor was stuck in partial down position; worked the drawer out and found cotton fibers wadded/stuck at top of the up/down...
May 24, 2011 | KitchenAid Microwave Ovens
Kitchenaid compactor KUCS03FTSS makes banging sound at end of cycle
May 17, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Ram will not reverse at end of cycle
ive been a repairman for 17 years but havent had to fix a lot of these because ther not out there,but have done some.it drives on a worm gear and i suspect that theres some wear there and its jumping the gear and thats where your getting the poping noise.their not the funest but you,ll have to take apart and opperate and watch/inspect.hope that helps God bless
Jan 03, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
Kind regards,
Paul
Netherlands
Dec 30, 2008 | KitchenAid P Series Trash Compactor -...
Hope this helps.
Steve
Nov 20, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
KitchenAid Architect S Series II KUCS03FTSS Fully Integrated Trash Compacto Logo
224 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
