I have Carrier mod#24ANA760A300 Infinity system. 1.5yrs old. Compressor nor fan outside will start. The controller on unit flashes an error for low pressure switch open (error #32). Gas pressure is normal! My technician says that he will have to order a new compressor because of some checks he has done. What I need to know will the controller show low gas pressure if the unit has never started even though the low pressure switch is closed as it should be with proper levels (checked the switch and is closed less than 1ohm across it).
  • cohrs_gen Jul 22, 2009
    The switch was isolated when tested. I also tried the system with the circuit open to the board, no switch connected to it, open circuit, which should have changed the error code to an open circuit symptom or tripped condition (#83). Nothing changed, I shorted out the connection to the board at the socket to simulate the switch closed but still no change. Will the board give this error until the system actually starts or is the board giving incorrect errors.
  • vaneddies May 11, 2010
    did you isolate the switch when tested? can you bipass the switch to see if if you have functioning comp/fan?
  • 158 Answers
No unless there is a loose connection of the wires or terminals between switch and controller
Posted on Jul 22, 2009
  • relaga58
    relaga58 Jul 23, 2009
    After bi-passing the switch did you try off and on circuit breaker, sometimes main PCB board needs to reset this way. This board when doing weird things needs replacing.
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
A Carrier mod # 24ANA760A300 Infinity with an error code #72 high stage thermal cutout, What causes this?
if it's a thermal cutout that's mounted on the circuit board you may have to replace the whole board. I don't have the carrier error codes at hand. But a "thermal cutout" is normally found on the compressor. One advantage of the old (before digital) systems is that the controls were all separate. So you could replace a bad high pressure switch or contactor. Without having to replace a expensive circuit board that held most of the controls.
Not to mention being easy to damage by power surges and lightning
Jul 11, 2012 | Carrier Heating & Cooling
Fan out side is not working
Does the compressor come on? do you hear any humming?
Aug 14, 2011 | Carrier 38CKC042 Air Conditioner
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
Carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
Jul 07, 2009 | Heating & Cooling
Compressor fan and compressor not running new 2 yr old system puron
No power to outside unit. Check to see if contactor on outside unit is pulled in. Most AC units inside have float switch. When the drain stops up it shuts off outside unit. Located in overflow or underneath unit. No Problem Rusty
Jun 05, 2009 | Carrier 38CKC036 Air Conditioner
Compressor shuts down when warm outside
make sure you provide shade for your unit. It may help keeping it cool.
Aug 27, 2008 | Honeywell Electronic Programmable...
I have a Carrier infinity model 38tdb037-3. The outside unit will not come on. the control board on the outside unit shows an amber led on status 2.it is a steady constant flash.the error is an apparent...
Have you eliminated the possibility of a high or low pressure error. Sounds to me like it's off on safety. Should have troubleshooting the flash right on the panel. Test your pressure switches for continuity.
Jul 13, 2017 | Carrier Heating & Cooling
I have a carrier infinity system. On the thermostat it reads "sens error" where the outdoor temp is normally displayed. The inside unit is running but the outside unit is not. Any suggestions?
A burned or pitted contactor will/can cause a unit to not run. Outside fan. Just thinking out loud. Start with low voltage check at t.stat then check outside low volt. Set t.stat to on. If fan engages at least your transformer is good. Next set calling for cool. Drop t.stat 68-70. If nothing happens go outside and with a screwdriver depress the contactor in. If fan and compressor kicks in change the contactor. If contactor is pulled in check outside fan. Remove the wires from the compressor and see if the fan will run . If it does you have eliminated start components as good. The compressor has to be check. It needs to be ohmed out. Turn off power at disconnect. Pull the cover on the compressor. Check between pins; then pins to ground. Open or infinite is good.Have you checked fuses. Like small 3-5 amp fuses
Jul 03, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
605 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
