Weber Genesis Silver C Grill
Problem for Weber Genesis Silver C Grill
Grill does not heat over 250 degrees
By bonesdoc on Jul 22, 2009
have changed gas tank
Best Solution
posted on Jul 29, 2009
Very Helpful)
Fireplacegir
Rank: Wiz
Rating: 94%, 65 votes
Here is a couple of things to do.
Make sure your tank is filled.
Straighten Fuel hose, so it is not bent or kinked.
Does your front burner light with a match? If it does light then check the Crossover Ignition System.
Also, It could be the way the unit is turn off.
Try following thses steps, this will help to reset the excess flow safety device.
Turn all burner control knobs and the cylinder valve OFF.
Disconnect the regulator from the cylinder. Turn burner control knobs to HIGH. Wait at least 1 minute. Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve on slowly. Then go ahead an light your grill.
Fireplace-girl
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Jul 22, 2009
Not Rated)
bozcro
Rank: Wiz
Rating: 83%, 412 votes
very likely if its an older bbq, the burners are full of rust and need to be replaced. nextthing the pressure regulator (on the hose that goes on the tank) is faulty) last thing to check would be the jets (under control dials)
Was this helpful?
Yes
No
Popular Solutions for Weber Genesis Silver C Grill
Questions and Unsolved Problems for Weber Genesis Silver C Grill
Do you recommend Weber Genesis Silver C Grill?
Answer
Answer
my weber grill won't get hot--only goes to "test"
Answer
Weber gas grill not heating up past 350. Tank is filled. I can smell gas but tank not leaking
Answer
How do you reset the safety valve on a gas grill.
Describe your Grills and Smokers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Grill and Smoker Experts
Top Range & Oven Repairmen
in , AK
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
Best Grills and Smokers
Recommended by Owners
See more>>
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
