Question about Canon Office Equipment & Supplies
Lack of use...dried out cartridges...replaced, ran "deep clean" utility and still won't print recommendations?
    President:
  • 3,278 Answers
I'm not certain that anything will work, but give this a try (someone else at FixYa had suggested it): place newspaper underneath the cartridges and spray the nozzles with Windex. Hope this works.
Posted on Jul 22, 2009
    Scholar:
  • 117 Answers
Can you remove the print head? If so run it under warm water for a little bit and then dry it off but becareful if the circuit board on the back if it has one. Once completely dried off reinstall it and run the deep clean again.
Remove print head canon mp480
THe print heads are an integral part of each cartridge. When you remove the cartridges you actually remove the print heads. You will need to open the top front panel to access the print carriage which moves left and right over the paper under it. Using cotton swabs you can apply rubbing alcohol to the places the cartridges rest upon and absorb all the dried out ink. Be sure you toss the old cartridges out before you reassemble. If you need to store any ink type printers REMOVE ALL CARTRIDGES and clean off the receivers on the print carriage!
Dec 31, 2012 | Canon Pixma MP480 All-In-One InkJet...
How do you go about cleaning printer head
there is a cleaning utility "printhead clean" and printhead deep clean" under "maintenance" in the "printer properties". Try that first. If that doesn't help and there is definitely ink in the cartridge(s), you can remove the cartridges and soak the printheads in 5mm of hot water for 1/2 hour or so. DRY WELL then install back in printer and run "printhead deep clean".
Another way is to isolate the colour that doesn't print properly and print few pages in that colour (eg if yellow is not printing right...set out a full page of yellow background and print on high quality setting until yellow starts to print ok). This wastes less ink than the cleaning utility.
good luck with it
LC1000
www.inkbank.com.au
Dec 02, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
Ran out of black ink. replaced cartridge. now
If it ran dry before you replaced it then you need to do a deep clean of the head. This can be done under the maintenance tab of printer properties. If that doesn't get it working then physically remove the print head and clean it with a water moistened cotton bud (make sure you use a separate cotton bud for each ink nozzle). Running a cartridge completely dry can (and often does) damage the print head (overheats due to lack of cooling provided by the ink flow).
Oct 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Carriage cycles normally but no ink on paper.(Stylus color 880)
Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
Jun 28, 2009 | Epson Stylus Color 760 InkJet Printer
My HP 640 will not print. Ran the test, no print.
If these are new cartridges, make sure you removed all of the protective plastic wrap that comes when packaged.  usually its red , yellow or orange plastic tab that should be removed.
If these are not new cartridges, you may need to try another set.
Try running the head cleaning utility under the printer utilities options HP is very good at having this utility available to trouble shoot most common problems.  If you don't have this utility, try updating your printer driver. (basically uninstall the printer and download the driver from the HP website, and reinstall the printer using the latest driver).
Hope this helps..
~enov8
Mar 07, 2009 | HP 640 Inkjet Fax Machine
Claims new ink cartridge is low...
Hello, at this point I would suggest COMPLETELY uninstall your photo printer, reboot your system and reinstall. Hopefully this helps.
I will tell you though, usually if after running cleaning utilities, the picture still has lines and spaces, could be due to print heads drying up and unable to output the proper amount of ink. This happens alot when people are not using their printer often enough to keep the ink flowing properly.
Recently I had to replace a printer that I had not printed on in like 3 months, the print heads dried up/ clogged up. And the new ink I had just purchased was a waste of money. Had to replace entire printer.
Feb 04, 2009 | Epson PictureMate Photo Printer
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
My Canon S750 Bubble Jet Printer does not print with black ink. It seems to print all other colors though.
Replace and install the black ink cartridge with this Black Ink Tank BCI-3eBK Ifyou have done this and is still missing the black ink on print, clean the print heads. 1. Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'. 3. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
That should most likely work. If deep cleaning did not help, you may need to replace the print head.
Nov 25, 2008 | Office Equipment & Supplies
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
old marine
old marine
