The LG Window Air Conditoner was chose because it
The LG Window Air Conditoner was chosen because it was supposed to be quiet. It sounds like an airplane taking off. Suggestions to correct this would be appreciated.
  • L.Stella Jul 19, 2012
    We chose the LG also for the same reason quiet!! OMG it is so loud, like you said an Airplane taking
    off
  • 867 Answers
Try pressing around the unit with your hand while unit is running, the sheet metal may be loose or vibrating against something wedge it something and check for loose screws.
Posted on Jul 22, 2009
Need manual for emerson quiet kool air conditoner model 12HT13?
I found this I hope it helps.
Performance BTU/H Cooling: EER: Voltage: Amps: Watts: Cooling Area (Sq. Ft.): Pints/Hour: Room Air Delivery (CFM): Plug Cap Amps: Plug Type: Dimensions Width: Depth: Height: Net Weight: Shipping Weight: http://www.appliancefactoryparts.com/airconditioners/emerson/12ht13.html#Manuals
Jun 02, 2014 | Emerson Quiet Kool 12HT13 Air Conditioner
We have a kolin S Series air conditoner it displays an F2 error code only fan is working no air con
Try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you have any other Air Conditioning Repair Questions don't be afraid to let us know.
Feb 28, 2014 | LG Heat cool Window Air Conditioner
Dropped air conditoner 2nd storie now hissing what to do with it
wait for it to bleed off then scrap it.usually not worth repair and recharge
Sep 27, 2012 | LG Electronic Window Air Conditioner
Window air conditoner runs constantly
the termostat is broken . you need to change it
Jun 29, 2012 | Kenmore 76081 Wall/Window Air Conditioner
I just purchased this portable air conditioner. I have a few questions about its operation and intimation. First, my window is a vertical sliding window that is about 55u inches tall. Do u have anything...
LG does not currently have an extender panel. However, call Vance Baldwin/Encompass at 1-866-779-7906, as they may can help you with that.
As far as noise is concerned: Generally speaking, most noises heard from the air conditioner are normal sounds of operation. Most of the time, noises are muffled during the day by activity in the home, but heard at night when it is more quiet.
Vibrating Noise? This is most likely the result of improper installation. Check that the unit is secured properly in the unit. Make sure the filter and the front grille are attached properly.
Hissing/Gurgling Noise? At the ON/OFF operation is caused by the refrigerant flowing inside the air conditioners sealed system. THIS IS NORMAL. This sound is a little louder for 2~3 minutes when the unit is first turned on. This is the sound of the compressor start-up. THIS IS NORMAL.
Beeping sound when control settings are selected/changed? THIS IS NORMAL. This noise is a signal that the control panel settings have been changed.
Pinging Noise? THIS IS NORMAL. This is the result of moisture in the base pan being picked up by the fan (called a slinger fan) and thrown against the condenser. This helps to discharge the heat and make the unit cool more efficiently.
Is the unit installed in an enclosed are? A unit enclosed by many walls is likely to produce more noise as the sound waves will be reflected and echoed.
Once the room temperature is met, the compressor should turn off automatically. But, the fan may run for several more minutes.
I hope this helped you. Thanks for choosing FixYa.
Jul 24, 2011 | LG LP0910WNR Air Conditioner
I just put my air conditoner in my bedroom window and now all i can get is 3 channels. when the air conditoner was not in the window the t.v was ok
Sounds like you are getting interference with the AC. Can you plug the AC into an electrical socket on a different circuit?
Jun 11, 2011 | Computers & Internet
Power cable is out of Air Conditoner what to do in this case?
Hi, if the unit fell and pulled the cord out, all you can do is to wire it back in. The unit is probably 220 volts, so it will be fairly easy to do. Look at the wiring and see where the wires have come off. All you have is 3- wires and a ground. Look at the wiring diagram, and it will show you exactly how to do this.
Shastalaker7
Jun 09, 2011 | Goldstar LG L1004R Window Air Conditioner
The fuse bloww try replacing it but keep
Has this air conditoner been running on these fuses for awhile, and is it just now starting to blow the fuses? If so then have a short in the air conditioner. If this is the first time you're trying to run this unit on these fuses, then you need to check the rating plate on the air conditioner for the full or rated load amps and see if your fuses or the outlet rating will carry the amps the unit is drawing.
Aug 10, 2009 | Heating & Cooling
My air conditioner
angela,
the slimy pink substance is the product of long usage and is a normal accumulation of dust and dirt.
have a regular cleaning of the unit to prevent another occurrence of the water not draining out. usually every three months depending on the location of the unit.
tnx 4 using fixya,
drcool
Sep 13, 2008 | LG Electronic Window Air Conditioner
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
