Question about Dishwashers
Tablet not fully dissolving. dishes not clean after wash.
The tablet is not fully dissolving after a wash and the dishes are not being cleaned. The dishwasher sometimes stops part the way through the wash, when the door is opened and closed it continues the wash.
  • 864 Answers
The water is not hot enough. It may be pausing to heat the water and when you open the door it resets and starts again. Check the electric element at the bottom that heats the water to see if it is burnt out.
Posted on Jul 22, 2009
Dishwasher not washing the tablet does not dissolve
I quit using the tablets a long time ago...just like you, they never really dissolved, and left residue on my dishes. I only buy liquid now, try a few out. You will be surprised when all of your dishes are actually clean, and nothing is left in your dishwasher when it completes. Best wishes with going back to where we started years ago...sometimes older things are better at doing things* Michelle~
Dec 21, 2017 | Miscellaneous
Whirlpool wdf310paa not cleaning dishes
Check water supply. Saddle valve failure can restrict water flow. DW
Apr 12, 2014 | Whirlpool Dishwashers
Tablet not desolving after quick wash cycle
Find out whether your quick cycle is a wash cycle or a rinse only. If it is a wash it's obviously too short, and the tablet is not dissolving. You do not want undissolved tablets because they will contaminate your rinse water and u end up with soap on the dishes. You can switch to powder if a tablet isn't going to dissolve quick enough on your quick cycle.
Jun 03, 2011 | Bosch Dishwashers
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
Clothes smell of old dirty water, after washing
this will solve your problems
Affresh™ Washer Cleaning Kit Affresh™ Washer Cleaning Kit contains 3 Power Puck tablets and 6 Grit Grabber cloths. The tablets remove and prevents odor-causing residue that can occur in all brands of HE washers. Affresh™ cleaner is a formulated, slow-dissolve, foaming tablet that gets under residue, breaks it up, and washes it away leaving the washer smelling fresh and clean. Simply place one tablet in the wash basket (without clothes) and run a Normal Cycle (hot option) or Clean Washer Cycle. The Grit Grabber™ premoistened cloths have been formulated to penetrate, dissolve and remove odor-causing residue from the rubber door seal. Now consumers can clean where they can't reach with the Power Puck™ tablets and where they can with the Grit Grabber™ cloth. Affresh™ brand is environmentally friendly, safe on septic tanks, and safe for all washer components. Package includes three tablets. Part #W10194073 $10.99
Please remember to leave a solved rating!
Dec 07, 2008 | Whirlpool Washing Machines
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
I have a Chef Classic dishwasher - not washing properly
The caddy for cutlery on this model is in front of the compartment where you put the tablets. What'll sometimes happen, is a spatula or wooden spoon or something in the caddy will hold the tablet compartment lid shut - it'll stop them coming out properly.
After a while the water movement will move the obstruction and the tablet will come out, but it'll only be dissolved for a bit of the wash and the dishes won't be cleaned properly.
Dec 18, 2007 | Magic Chef CDB6100 Built-in Dishwasher
Water not hot
Dishwashers are suppose to be hooked up to hot water. If you had hotter water it would clean just fine. 120 deg or more!
Nov 01, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Dishwasher tablets not dissolving
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Apr 10, 2006 | Bosch 24 in. SGS66E02 Exxcel Built-in...
Dishwashers Logo
241 people viewed this question
Top Dishwashers Experts
