Question about Remida Automatic Citrus Remuk4 Juicer
Remove steering lock plate
Olds 89 delta 88 I have the wheel off but can't figure out how to pull the lock plate off I do have the tool
0 characters
1 Points
I am taking my juicer apart. I took the three screws out and the grinder plate. How do I get the filter out that is beneath the grinder plate.
Don't take the screws out! That plate is not meant to come off.
The filter unit is removed from the base by unscrewing it counterclockwise using the two holes in the plate that you unscrewed. The juicer originally came with a plastic tool with two prongs that fit in the holes and acted like a sort of handle you could use to unscrew the assembly.
If you don't have the tool, you can use two small screw drivers or jury-rig a tool out of a piece of coat hanger shaped into a U to gain leverage to dismount the entire filter/blade assembly for washing.
Hope this helps!
Mar 03, 2011 | Jack Lalanne Power Juicer 250 Watts
When I disassemble for cleanup, the basket is very difficult to get out of the bucket part. Any tips?
The basket may have cut into the hex shape top of the spindle creating little grooves which
the basket locks into. If that's the case you have to replace the part, it's called the impeller.
If you can purchase one from Omega, use a needle nose pliers to remove the flat hold down
washer/nut on top of the motor spindle, pull off the old impeller and push on the new. Line
it up correctly it only installs in one position. The impeller is the flat rotating part that the
basket sits on. I did it on my Acme but had to push a little for them to sell me one.
Nov 29, 2010 | Omega 1000 Juice Extractor
Can't find the manual and have forgotten how to take it apart to clean it
Most juicers have a retention rod or side snaps that hold the top of the juicer in place. By loosening these, it will allow you to get underneath the juicer cap top. Once you have done this, you will have to remove the juice/ pulp wheel blade. Your juicer should have come with a two pin tool that facilitates this. Use the tool to loosen the juice /pulp wheel blade. Once you have done this, you should be able to remove the outer juice capture rim with that has the spout on one end. I hope this helps. Good luck and happy juicing.
Jul 18, 2010 | Juicers
No crescent tool included with purchase to remove the blade
Make sure the Juicer is unpluged. What you need is the cresent tool or two metal objects to place in the two holes opposite each other and press down the metal objects in the holes while turning counter clockwise. It kind of acts like a lock and key system.
Jul 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Flashing sidelights on citreon xantia M reg
There's a button with a speaker with a cross through it on the dash to the right of the steering wheel.Should be the furthest button to the left.Turn yr ignition on and within 10 seconds press and hold this button till the indicator lights flash on the dash.Problem fixed.
Jan 14, 2009 | Remida Automatic Citrus Remuk4 Juicer
Taking apart Jack Lalne power juicer to clean.
There are two holes on the surface of the blade. When the juicer was bought, it came with a half moon shaped orange tool that has two posts that fit into these two holes.
By inserting the tool into these holes you can unscrew the blade from the machine as long as you hold the outer screen while doing so.
Once this is done, you simply lift the other pieces off.
If you can't find your orange two prong tool, i would suggest using a screw driver or two that fit into the hole(or two)..... hold the orange screen and turn the blade counter-clockwise..
Hope this helps
Jun 06, 2008 | Jack Lalanne Power Juicer (Stainless...
How to dissassemble Jack Lalanne Power Juicer?
After about a half hour I finally figured it out. I'll go through all the steps.
1. Remove pusher from chute.
2. Pull the locking bar down over the spout.
3. Remove lid.
4. This part is tricky. Stick the orange crescent tool into the blade holes and while holding the filter basket steady with one hand, turn the blade couterclockwise while pulling up.You do have put a little muscle into it. And remember, if you don't hold the filter steady, the whole damn thing just spins.
5. Remove the receptacle.
Good juicer, but it seems unnecessarily complicated.
Jan 01, 2008 | Jack Lalanne Power Juicer 250 Watts
How to replace latch arm for omega 1000 juicer?
Getting the old one out is the hardest part if the arm was broken off like mine. First locate the rectangular part where the arm attaches to the case. If the old arm, or most of it, is still attached, grasp it and pull firmly away from the case until you hear a click. Then, still pulling it away from the case, push it up toward the top of the case until it slides out. If the arm is broken off you have to pry it from the top until you hear the click. I used a small paring knife. Once you get it this far, wedge something like a toothpick behind it to keep it pulled away from the case. Then you need to push this push this part up. It is pretty tight so you might want to use some type of tool, like the blade of a flat screwdriver. Once you get the old one out, putting the new on in is just the reverse of taking the old one out.
Dec 11, 2007 | Omega 1000 Juice Extractor
How to clean juicer
i had the same problem and figured out an easy way to open it without the tool. DO NOT take out the screws. I simply used chop sticks. I put one in each small hole and held the chop sticks in an X and turned the top counterclockwise!
Jun 10, 2007 | Jack Lalanne Power Juicer 250 Watts
Remida Automatic Citrus Remuk4 Juicer Logo
35 people viewed this question
Top Remida Juicers Experts
Brian Sullivan
Brian Sullivan
Are you a Remida Juicer Expert? Answer questions, earn points and help others
