Question about GE Spacemaker JVM1640SJ Microwave Oven
The interior light in my G.E. Spacemaker convection/ microwave oven does not light when cooking or opening the door. The model # is JVM1490SH02.
  • ljw1945 Jul 22, 2009
    Excellent- I would also suspect the bulb rather than the door switch. Being in a motorhome, the microwave is subjected to a lot of vibration.
    Thanks for the drawings. I have printed them and will have them for future reference. Jay Walker
  • GE Master
  • 13,433 Answers
Hi
I suspect that the issue is either the bulb or one of the switches on the door.
If you look at this diagram.
http://www.partselect.com/ModelFrames.aspx?ModelID=501361&ModelNum=JVM1490SH02&mfgModelNum=&ManufactureID=2&Selected=00119829i03&Position=2&mfg=GE&Type=&Mark=2
there are 3 switches on the door area it may be somewhat difficult to read but the door switches are numbers #1445 and #1446 - there are two (2) #1446 switches
one of these switches is not working anymore as when the door is opened it opens and closes a switch or two - turning the light on.
here are more parts and diagrams
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=JVM1490SH02&mfgModelNum=&fkMfgID=2
but this somewhat strange that the light doesn't come on even when cooking, It might not be a switch issue, most likely the bulb is blown and would need to be replaced. Actually it appears to be a HALOGEN LAMP shown on "oven cavity parts" diagram and the number is #282
I would first test the old lamp / replace the lamp and if it still doesn't light, check the wires from and to the lamp and see if you can figure out which switch controls the lamp.
For this repair you will need a multimeter and screwdrivers I expect that you have experience in using them and ofcouse unplug the oven.
if you don't have a multimeter or the tools or you don't think you can take it apart and sort the problem you might want to get in touch with a microware repairer. Ofcourse if your microwave is still covered by warranty you shouldn't do anything and just contact the company or your dealer for warranty repair.
Posted on Jul 22, 2009
I have an Advantium 240 mounted over the range. There's a little trap door that covers an interior light while cooking. My door gets stuck and I hear a motor run. How can this be repaired?
That's the damper. It has to be closed when microwaving, and open when convection cooking.
See my video and also see the description text here GE Advantium microwave oven clicking noisy SCA1000 SCA2000 for more information.
Please note the phone number in the video is incorrect. See the Web site for more.
Nov 24, 2016 | Microwave Ovens
GE XL 1400 Spacemaker Microwave
Clean all the visibility of the microvave which causes the light switch logged. pls consult the user manual in cleaning the oven.
may help, melnavz
Apr 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How to install interior light bulb in ge microwave oven model jvm1490sh02
by removing the outer case is the only way I have seen
Mar 01, 2015 | GE Microwave Ovens
Interior light stays on
Need a bit more information here. Does it still cook when told to do so? If not, you may have a problem with the door close switch. Perhaps it is as simple as using a screwdriver to finesce the actuator back into position. The inside edge of the door has a metal latch and often times a slightly shorter pin or tab that actuates the door open switch. This not only enables the light in the microwave to turn on when the door is open it also tells the cooking circuits to disable until the door is properly closed. If the switch itself is bad you'll have to take the microwave apart to get it out. RepairClinic.com has a huge assortment of parts that are easy to search and find.
Feb 28, 2015 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker Micro/Oven Need to change (inside) light bulb on model #JVM1490SH02 Serial # TH901044K. Where is the bulb located?
While replacing the cooktop light can be done by accessing the cover on the bottom of the oven, replacing the cavity light will require you to pull the oven from the wall and remove the outer cover.
The installation instructions are very handy in this case, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Elite Advantum 120 Model # 363-63694302 INTERIOR Light not working
I would suggest you look over this excellent tutorial.
If this is not close enough to your oven to help, please reply back.
Oct 05, 2008 | GE Advantium 120 Convection/Microwave Oven
Light fails to operate with door open
If the light comes on during cooking then the bulb is ok.. in all probability the problem is the door switch that senses when teh door is open and activates the light... Hope that helps..
Aug 15, 2008 | Frigidaire GLMV168K Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
GE Spacemaker JVM1640SJ Microwave Oven Logo
35 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
