Sound cuts in and out - Audio Players & Recorders
  • 5,603 Answers
Most common problem is broken input connector or the soldering to the circuit board. I have replaced a bunch of these.
Posted on Jul 25, 2009
The sound on my TV keeps cutting out. It cuts out for 1-2 seconds. It does this approx. every 30 seconds. I have changed cables and cable box....no change. Any suggestions?
Sounds like the final audio amp MOSFETs are overheating.
After set has been off and unplugged check for dirt and dust clogging cooling fins and parts. Air must circulate for cooling. Remove dust with a gentle blast of air or an upholstery brush attachment on your vacuum cleaner.
If this doesn't work the parts usually cost more than a modern set is worth and I suggest purchase a new set.
Nov 26, 2015 | Televison & Video
Sound keeps cutting out
take to the repairers they will handle it parfectly
Sep 05, 2017 | Toshiba Satellite L755s5246 Laptop...
Mackie 450v1 when i turn on low cut switch the sound stops turn off low cut and sound returns
Dusty/Faulty switch and/or opamp inside pcb, let me know to help more/.
Jan 03, 2012 | Mackie SRM-450 System
Sound keeps cutting out. Have to reboot to get back. Please help
you can try uninstalling and reinstalling the drivers,or also try to update it
Jun 14, 2010 | Bose Companion 5 Multimedia Speaker System...
Magnavox rear projection tv - sound cuts off when
Problem with SSB module and will burn out a resistor on SSM board eventually and will have no sound at all.
Apr 12, 2010 | Philips Televison & Video
The sound cuts out all the time for a second
you might have a short in your wiring somewhere. If your power wire touches any kind of metal it will ground it out causing it to cut off.
Oct 31, 2009 | Car Audio & Video
The sound suddenly cut out for my Bose 321 GSX system
I now have this same problem. Would like to know if there is a fix or if my system is just failing for good
Apr 09, 2009 | Bose 3 2 1 GSX System
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Mar 26, 2009 | GE GTD120 System
Amp gain problems!!!
is more than likely a loose connection
Jan 18, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
81 people viewed this question
 Grubhead
Grubhead
