Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer had a jam, I cleared it but now the screen flashes 3 and E alternately. I tried turning it off, pulling the plug, turning it upside down in case something fell into it! NO LUCK - anyone have any ideas?
    Problem Solver:
  • 29 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tonl-i-5
Posted on Sep 04, 2009
    President:
  • 2,306 Answers
That error is saying there is still paper inside, you might try using an index card pushing it back thru the paper path under the rollers where the paper comes out to be printed, you should see a small corner of paper pushed back into the paper feed area. GOOD LUCK!
Posted on Jul 22, 2009
My printer says "printing" in the window but
Sometimes there is a jam and you can't see it. Take a flashlight and make sure there are no small pieces of paper or other objects in the way. You can also turn the printer upside down carefully and see if any small objects fall out. I've seen everything from fingernails to sunflower seeds jam a printer.
Mar 02, 2011 | HP PSC 2175 All-In-One InkJet Printer
Hi, My printer had a paper Jam and I am pretty sure some paper got stuck however i cant find any when lifting the top up.It now wont work and the alarm light is flashing ThanksJemma
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. Step2 Turn off the printer. Step3 Remove any paper trays. Inspect them for wrinkled or damaged paper. Step4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. Step5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. Step6 266_a1.jpg If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. Step7 266_a2.jpg If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything, though. Step8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Step9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
If you still face the problem let me know..
Goodluck..
Jun 03, 2008 | Canon Office Equipment & Supplies
My printer has a paper jam but there is no paper jammed in my printer what do i do?
run the roller cleaning application in maintenance a few times then turn your printer upside down and gently shake it side to side to clear any foreign objects that may have fallen down the paper feed.
I know it sounds silly but on 3 occasions now i have cleared the "jam".
Nov 30, 2010 | HP Office Equipment & Supplies
Pen gartridge jam
Is it an ink cartridge jam
Please follow steps below : STEP: Disconnect and Reconnect the Printer Power Supply
Unplug the power cord from the wall socket. Disconnect the power supply from the back of the printer.
Wait 15 seconds.
Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket
STEP: Raise and Lower the Scanner Assembly on the Printer
Lift the lid of the scanner until the locking bar catches to move the ink cartridge carrier to the center position.
Release the locking bar and close the scanner assembly.
If the ink cartridge carrier fails to center, repeat steps 1 and 2
Scanner Assembly Open but Without the Cartridge Carrier Centering
STEP: Check to See if the Ink Carrier Latches Are Open
Open the printer.
Check inside the printer to see if the cartridge carrier latches that hold the ink cartridges down have popped open.
Close the carrier latches
STEP: Remove any Torn or Stuck Pieces of Paper from the Input Tray and Output Tray
Disconnect the power brick from the back of the printer.
Lift the scanner unit.
Look down inside the printer and remove any torn or stuck paper from the input or output tray by pulling firmly.
Close the scanner unit.
Reconnect the power brick to the back of the printer
STEP: Clear Obstructions From the Input Tray
STEP: Fan the Paper
Grasp the **** of paper at one end (Figure 1).
Place your thumb on top of the opposite end of the paper and fan the paper like a deck of cards.
Flex the paper back and forth, and then fan it.
Straighten the edges of the stack on a level surface.
Top of Form 1
Bottom of Form 1
Additional Information
It is quite possible for objects such as pens, pencils, paperclips, and other small items to fall into the paper input tray causing paper jams to occur. Follow the below steps to try and clear any obstructions that may have fallen into the printer.
Caution:
The next steps involve lifting the printer and turning it upside down. Only perform these steps if you are willing and able to do so.
Remove all paper from the input tray.
Unplug the power brick from the back of the printer.
Unplug the USB cable from the back of the printer.
Lift the printer up and turn it upside down.
Caution:
Make sure that you are holding onto the scan bed to prevent it from falling open when the printer is turned upside down.
Tilt the printer from side to side while it is upside down to see if any obstructions fall from the input tray.
Jul 19, 2010 | HP OfficeJet t65 All-In-One InkJet Printer
Saying that I have a paper jam after I have
Try this :
turn off the printer
unplug the power cable
lift your printer up then put it in an upside down position
then shake your printer from left to right for about a couple of mins.
see if there's any foreign object stuck inside the printer.
After that
put the printer back to it's normal position
then plug the power cable in
turn on the printer
and check if you still have the error.
Feb 25, 2010 | Brother Office Equipment & Supplies
I have a canon pixma mp160 printer and the paper keeps jamming. I have cleared the paper area and there is nothing stuck. Can you help me out?
Turn on the printer upside down and start puling it upside down and then try turning it off and then on try then it should work
Jan 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I got a Paper Jam message while trying to print on Avery business card paper. Pulled back the jammed paper by reaching into the tray. Tried printing again, Jammed again. Removed the Jam Clear Cover in...
First off, NEVER EVER turn a componant upside down and shake it. Second, open the printer up and search for any additional paper. A lot of time a paper jam isn't just one sheet, especially if you have a faster printer. I would also try using some rubber rejuvinator on the printer so that it picks the paper up better so it goes through the printing cycle better.
Jul 17, 2009 | Brother MFC 210C All-In-One InkJet Printer
Paper will not feed correctly,,,it pulls off center and then jams
You have something jammed in the paper path of the printer. Un plug it, remove the paper, and turn it upside down. Something will probably fall out. If not, shine a flash light down inside and look. It's most likely a paper clip or something. This is a common problem with those type of feed systems.
Apr 15, 2009 | Dell 922 All-In-One InkJet Printer
Cleared a paper jam & now the printer will not turn on. We have checked to make sure there is no more paper jammed. We turned printer upside down as recommended earlier. Nothing fell out. We...
Hi, please check the power cord if there's any sign of damage. Try to connect the printer directly to the wall outlet or if possible plug the printer to reliable power outlet. If issue still persist contact printer manufacturer and call for service.
--->> Tirzo
Jun 12, 2008 | Office Equipment & Supplies
Problem with HP 7450 and "Paper Jam"
hi, mezz
try this
There are 2 different types of flashing patterns with those two lights on the printer.
Resume light and power light BLINKING ALTERNATELY
Problem: Paper is jammed in the printer.
Resume blinking SIMULTANEOUSLY with power light
Problem:
The print cartridge carriage is stuck.
Solution:
1. Open the top of the printer.
2. Remove anything that is blocking the carriage path.
3. Turn the printer off.
4. Turn the printer on.
Problem:
There is something wrong with the printer. (I didn't write it, I am pulling this from actual HP tech documents, so don't blame me on this one) :)
Solution:
If the printer will not turn off, unplug the power cable from the electrical outlet or wall outlet.
Unplug the power cord from the back of the printer.
Wait about 30 seconds.
Plug the power cord back into the wall outlet.
Plug the power cord to the back of the printer.
oke, post in me back
tq
cropp
Jan 24, 2008 | HP Photosmart 7450 InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
65 people viewed this question
old marine
old marine
