Question about Canon BJC S500 InkJet Printer
Canon s500 blinking green and 7 yellow
Problem occurred after replacing all the ink cartridges.  took print head out and completely cleaned........after doing the reset procedure I found on the blog on this website, I was able to print a test, and subsequent pages just fine.  Turned off the printer and now blinking yellow 7 times again and not able to reset. What can I do, or it is time for a new printer?
  • 1 more comment
  • dmgood113 Apr 06, 2008
    I'm having exactly the same problem. I have cleaned all the contacts, restarted the computer and the printer and reloaded the software. Still not working.
  • Anonymous Jul 23, 2008
    Same issue, removed and reinstalled drivers. Printer recognized during that proces. However, would not print test page or from Word, or Notepad. Green light, 7 yellow lights, then green flash..back to 7 yellow flashes. ????
  • Anonymous Dec 23, 2008
    I have the same problem. I found a site that has the users manual - manual says that 7 blinks indicates a faulty print head. Try removing it and cleaning, if that doesn't work, it will need to be replaced.
  • 24 Answers
SOURCE: Missing Colors
This is a simple problem just reset your printer's color management settings!!!!!!!!!!!!!!!!!!!! :-)
Posted on Oct 24, 2007
SOURCE: Canon Pixma 1P1600
printer driver canon PIXMA iP1600
Posted on Jan 26, 2008
SOURCE: Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Aug 12, 2008
SOURCE: My yellow ink cartridge won't print only, I REALLY HAVE TRIED EVERYTHING
What kind of bathroom cleaner worked? exact name? Thanks
Posted on Aug 16, 2008
  • 68 Answers
SOURCE: No ink is getting to printhead in imagePROGRAF w7250
Your printheads are indeed clogged. (Note: all ij printers should be powered off when not in use! This retracts & seals your printheads.) Now, on to your problem. In your printer software, there should be a maintenance section. In there, you need to clean the printheads - this may have to be done *many* times - like 10-ish to clear (if still possible) clogged ink.
Hope this helps.
Posted on Mar 19, 2009
Canon ip100 portable printer ink cradle stuck on right hand side
I had this same problem. Count the number of blinks in sequence of the error light. it will flash green and yellow, and then just straight yellow for a number of flashes, then it will flash green again and the same number of yellow flashes again. Here is the diagnostic guide.
Two flashes: Printer is out of paper. Paper does not feed
Three flashes: Paper jam
Four Flashes: The Print Head Lock Lever is not locked properly / Ink tank is not installed properly. / Ink may have run out
Five flashes: Print Head is not installed./ Print Head is defective
Eight flashes: Ink absorber is almost full
Nine flashes:No response from connected digital camera or video camcorder/Connected digital camera or video camcorder is not compatible with this printer./PictBridge compliant devices are attached to both Direct Print Port and Bluetooth Unit Connector
Eleven flashes: Automatic Print Head Alignment failed
Twelve Flashes: Low battery level
Fifteen Flashes: Ink tank cannot be recognized
Seventeen Flashes: Ink has run out
Eighteen Flashes: Printer detected ink out condition
Nineteen Flashes: A USB hub is connected
Mine had 10 Flashes and the Print Carriage, was bad. Cost almost as much as another printer so thats what I did. I did take it apart and got it unstuck, but still didn't work.
Mar 10, 2014 | Canon iP100 Portable Printer
Resume not working
Sounds like head failed replace it see below
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Oct 23, 2009 | Canon BJC S300 InkJet Printer
I have a Cannon i560 and I am getting 5 blinking yellow light the green and then it repeats. All indications is that I need a new print head. I want to be sure this is it before buying the print head.
5 blinking yellow or 7 blinking yellow in canon printers means you need to replace the ink cartridge or head with a new one. If you want to be sure, then take the print head and see if there is any burned area or damaged near the head and sometimes it is very small like a needle puncture. if there is, you need to buy a new one. if not, try to clean the head with 96% alcohol, let them dry before you try to put it back.
Sep 14, 2009 | Canon BubbleJet i560 InkJet Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
7 yellow flashes not printing
hi welcome to fixya!
I believe there is no print head failure happening. I experience that one time, it only needs a new ink cartridge. Be sure to replace the right color!
have a nice day!
Apr 17, 2009 | Canon i850 InkJet Photo Printer
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Canon s520 problem
I solve mine (4 Yellow Flash + 1 Green) by pushing on the white gear, located at the end right inside, where the cartridges are cleaning. This help the movement of the gear, it was stuck or gem. Do this when you just turning on the printer, then you ear the cycle noise, Your fingers will sense the movement of the gear. Tips: Push the cartridges block to the left to let you enough space to put your hand inside.Now it work normally.
Feb 12, 2008 | Canon S520 InkJet Photo Printer
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
Oct 19, 2007 | Canon S520 InkJet Photo Printer
Canon BJC S500 InkJet Printer Logo
406 people viewed this question
old marine
old marine
