Question about Pride Value Line Revo Scooter 3 Wheel
HAVE PUT SCOOTER TOGETHER AND CHARGED BUT IT CONSTANTLY BEEPS EVEN BUT WILL NOT RUN THE HORN AND LIGHTS ALL WORK BUT NO MOTOR ITS A SHOPRIDER DELUXE 4 WHEELS
  • 103 Answers
Make sure the scooter is not in freewheel.
Posted on Jul 23, 2009
Shoprider sprinter deluxe do I need to put grease in gearbox where surts are ? front motor runs slow and hot. back motor is good
Hi again I checked shoprider site on you're model and there is no mention of a front motor it only gives a listing on a 2 HP motor plus I checked monster scooter parts only one motor in there parts listing.,.???? Have u got the correct model. u don't have to put any oil in the transaxle unless u have dismantled it ...not sure what u mean by front motor .???? Cheers
Aug 01, 2016 | Shoprider Sprinter XL 4 Deluxe
I have a shoprider echo when I turn it on the power meter works. The horn works. But there is a beep every 3 seconds. Please help
Your Throttle maybe out of neutral when you start the scooter.
Make sure your parking brake lever is on so the scooter is hard to move. If it is easy then it is not on and won't drive. Make sure there are not any cables that are disconnected to the motor and brake. Scooter Doctor App
Apr 28, 2016 | Shoprider Health & Beauty
I have a shoprider 888se mobility scooter i have full power,lights work,horn works but when i put key on does nothing except make a high pitch sound.What could be the problem
If the sound changes with the pressure on the throttle your gearbox may have stripped gears. Replacements are not cheap. The motor may have to come off to see if the connection is somehow slipping. Scooter Doctor App
Apr 25, 2016 | Shoprider Health & Beauty
Why don't the turn signals flash on shoprider cadiz deluxe?
hi Vic, there a little black board under the tiller part , it got a ribbon cable to it so take care if looking at it , there's a fault with the circult..
Regard
Rob
Help me Help you ...
Sep 24, 2015 | Shoprider Health & Beauty
I installed new batteries and scooter still doesn't run,why?
Check the wiring from the controller to the motor, disconnect the wire ad clean the connections with a contact cleaner or WD40 , and make sure the scooter not in freewheel mode.
Regards
Dec 14, 2012 | Shoprider Scootie
It want run the lights come on the horn blows
Download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.I hope this has helped.Colin.
Dec 05, 2011 | Shoprider Sprinter Deluxe Four Wheel...
Constant beeping, won't run
The beeping on shopriders usually means that the Main Control Box is faulty. It may also be caused by the Throttle Pot being out of neutral. This is a common promlem on this model of scooter as they use a Plastic throttle control lever instead of a metal one. Unfortunately, the plastic one's sometimes slip round slightly causing the above problem. Throttle pots can be very difficult to set to neutral without a multimeter so may be best left to you local dealer.
Jul 01, 2010 | Echo 3 TE SL7 3 New Electric Scooter by...
Shoprider xl4 deluxe has no power on inclines. lucky if it goes a couple of blocks even on the slightest grade ang the battery gauge goes to 1 light. Even with a fully charged battery has no guts on hills...
`Hi. Sounds very much like a loose battery terminal, or a faulty battery lead connector.
I have also had a few machines that can start jerking because of worn or stuck motor brushes.
Also check the high/low speed switch if you have one, they sometimes cause problems.
How old are your batteries, worn out batteries can still be " fully charged", but are unable to supply the current ( amps ), that the motor needs.
Good luck. Neil.
Jun 27, 2010 | Shoprider Sprinter XL4 Deluxe 4 Wheel HD...
Pride Value Line Revo Scooter 3 Wheel Logo
384 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
