Question about Panasonic DMR-E65 DVD Recorder
Panasonic DMR E65 cycling in self test on start up
My Panasonic DMR E65 cycling in self test mode every time I try to power it up. Have tried all the recomended solutions in the manual to no avail. Any idea's
  • 188 Answers
Check the IC in the primairy power supply,common fault.
Posted on Jul 22, 2009
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd keeps ''self checking'' and sometimes switches itself off
This is a known fault with the Panasonic DMRs. Basically, the main chip in the power supply circuitry starts to fail intermittemntly due to poor design of the heatsink.
If you search FixYa site it will come up many times.
Unless you or a friend can (safely !) identify, handle, desolder and solder electronic components, this is not a DIY repair.
If you can, like I said there are already several really good FixYa fixes for this.
Sep 17, 2009 | Panasonic DMR-E65 DVD Recorder
Search forward button (>>) on DMR-E65 remote inoperational
Carefully pry the remote apart (check for screws). Then you can take a q-tip and some alcohol or Windex and clean any dirt or contamination from the circuit board and the bottom of the button pad. You can some times see rings on the board where the buttons make contact and that is what needs cleaned off.
Sep 07, 2009 | Panasonic DMR-E65 DVD Recorder
DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
DMRE50
DMRE55
DMRE85
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
PANASONIC DMR-E65S
try other types of media- it's possible there's a malfunction in the motor drive electronics.
Re-post with your results
Nov 16, 2007 | Panasonic DMR-E65 DVD Recorder
DVD Recorder keps re-starting self test & will also not finalize discs.
This seems to be a common problem with the E55 and E85 models, could be one of two things, either the RAM Drive or the Power control ic (STRG6353 primary side of PSU), i would suspect its the latter. You'll need an engineer to replace this component.
Oct 29, 2007 | Panasonic DMR-E55 DVD Recorder
Dmr e85 will not start up
Hi Audi,
Try unplugging the hdd & then turn on the dvd recorder & wait for about 5 minutes.
Then unplug the dvd recorder & plug in the hdd & turn back on the dvd recorder to see if that fixes the problem.
Oct 18, 2007 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR E 55 cycling on/off
See this thread
http://www.fixya.com/support/t122832-powerdown_after_few_seconds
Sep 07, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E65 DVD Recorder Logo
992 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
