Back to:
Tags:
BenQ MP610 Multimedia Projector
Can't install mp610 printer
posted by lizzyw on Nov 20, 2007
I'm trying to install a canon mp610 printer on my dell inspiron, to replace the previous model, mp600. The installation disc won't complete the installation because it says another printer is set up on the computer, despite the fact I have deleted everything else in the "printers and faxes" icon on the control panel. I would be very grateful for some help
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 14, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The drivers for the printers you deleted may not have been deleted from the system print server.
Play it safe and make sure you have source files for re-installing any print drivers you delete.
From the "Printers and Faxes" window, select File/Print Server.
Select the DRIVERS tab, delete any drivers referring to the Canon printer.
Reboot or alternatively, use the services.msc to stop and restart the print spooler service. Now try to install your new drivers.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on can't install mp610 printer:
I don't want to Accept this solution
Can you Help with these Multimedia Projectors problems?
Could you explain to me how to connect a infocus machine...
The projector still displays from computer if is through...
was working fine turned it off next day plugged it in...
benq mp 610 was given as a gift to a church now pastor...
Hi, just replaced lamp and reset timer. worked o.k then...
Loading problems.
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
