Question about Cooktops
After cleaning, one eye is trying to ignite ("clicking"). Stops when I unplug the cook top. I've made sure all is dry. Don't see anything "out-of-place". What next?
  • eliserx Jul 23, 2009
    Ginko's suggestion worked! Thanks so much!
  • Cooktops Master
  • 19,396 Answers
If the igniter is clicking on its own, and this happened right after cleaning the range cooktop, then that undoubtfully means that liquid had penetrated under the cooktop panel and now is causing a short on igniter contacts, wiring, or on igniter switch.
Try leaving the range unplugged for 24 hours, the problem should disappear. If it does not, then the cooktop panel must be removed to find out what happened in there, and you may have to replace wiring, igniter, or igniter switch.. In that case it will be helpful having the range model number (as on service tag).
y first unplugging the appliance for one day, keeping the range plugged to main after that liquid damage had occurred may cause more problems to the appliance.
Regards.
G.
Posted on Jul 22, 2009
All the igniters are clicking after cleaning - help!
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 18, 2010 | GE 30 in. JGP336 Gas Cooktop
Electric igniter continually clicks spontaneously
clean any debris around all the spark electrodes and any ground points near each electrode,food or grease will make them do this,make sure you use a cleaner like isopropyl alcohol or a greaseless cleaner and let dry good before starting unit,if this doesn't resolve the problem,then you need a new spark/ignition module for the unit,but this first step is much cheaper
Apr 09, 2010 | KitchenAid 31 in. KGCC505 Gas Cooktop
After cleaning my cook top, the igniters won't stop clicking. What do I do?
The electrodes have moisture around them still and you can assist in them drying with a hair dryer or even turning the stove tops on for about 15 minutes to assist in drying them out. Don't go ordering parts you do not need. Thanks, Rick
Mar 09, 2010 | Cooktops
Igniter will not turn off. Makes a clicking sound
Hi, normally what causes the igniter to keep clicking is spilling water or something down into the knob area. The water is causing a short circuit in the switch which is mounted on each burner valve shaft. If unplugging the range for several days to allow drying doesn't fix the problem, then one of the switches will need to be replaced.
Jan 27, 2010 | Magic Chef Cooktops
Loud buzzing noise on GE cook top after cleaning
hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
tnx gerbee
Sep 11, 2009 | GE 36 in. JGP628 Gas Cooktop
Spark igniter discharging when turned off
Hi
It sounds like somebody clean up the stove and the electric sending unid is wet, try this: the knob that correspond to the ingniter that it's clicking nonestop, take the knob out and you will see the sending unit, pull it out unplug it and dry it out and then try it again, it should work properly after it's dry.
Eddie Rentas
Tupper Lake NY
Jan 11, 2009 | GE 30 in. JGP328 Gas Cooktop
GE Profile Cooktop was just cleaned and the burners cont. to clic
you must have gotten water down the igniter switches.try drying out underneath the knobs. or leave unplugged till they dry.
Dec 05, 2008 | GE Cooktops
Ingiters don't work - all burners
Unplug cook top. remove drip pan with screwdriver. Use hair dryer to completely dry area that might have gotten wet during cleaning. This may take five minutes. Put unit back together and plug in cook top.
Apr 27, 2008 | GE 30 in. JGP337 Gas Cooktop
Spark continuously on
If you have recently cleaned it, you may have gotten moisture behind the knobs and into the spark switches. Be very careful not to let moisture get behind knobs. Very dangerous. If this is the case, they may dry out themselves and stop sparking. If not you may need to replace a spark switch behind knob.
Nov 20, 2007 | GE 30 in. JGP336 Gas Cooktop
Cooktops Logo
41 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
