Question about Behringer EUROPOWER EP2500 Amplifier
I get a constant noise after I plug in the guitar
  • 1 more comment
  • peter_nejsum Jul 22, 2009
    its a Behringer AC108 Vintager amp, only one guitar input...when I start it up, its silent for a few seconds, then the noise starts...and when I plug in the guitar, the noise is still there
  • Rommel Cana
    Rommel Cana May 11, 2010
    hi, is there guitar input in EP2500? maybe on your mixer
  • Behringer Master
  • 5,603 Answers
The reason for the few seconds delay is that this amp uses a vacuum tube preamp which has to heat up before it operates.
Now with most amps at high gain you will get some noise, but it should be well below the level when you are running program material through it. The statistical electronic noise will be more of a hiss. If it is hum you are getting, then the filter caps MAY have failed. Also if you have light dimmers can sometimes get into the equipment.
First step is describing the type of noise. Behringer is VERY stingy on supplying schematics. Essentially they WON'T unless you are one of theior certified techs.
Your amp SHOULD be simple enough to fix without schematics UNLESS it has one of the Behringer digital effects. That board has a chronic failure of the DC filter cap.
Posted on Jul 31, 2009
My Ibanez acoustic electric has very weak volume and makes a constant white noise hiss when plugged into an amp or sound system. Batteries are new as is the pre-amp and under saddle piezo. Ideas?
It will be either the saddle pickup or the guitar pre amp. If you unplug the pickup and the hiss is gone, there was your fault. Otherwise fit a known good pre amp.
Feb 02, 2017 | Ibanez Music
I recently purchased a Fender Classic Player Jaguar Special HH as well as a Fender Super Sonic 22 amplifier. I noticed there is a lot of noise coming from the amp with the jag plugged in, especially on the...
"Noise" is not a very good deescription... is it hum? is it static like? is it a buzz? Hum pickup by the pickups of guitars are common and some pickups are worse. If it is hum move the guitar away from magnetic sources like amps, motors, flourescent lights, dimmers... etc. Sme guitars have grounding problems and touching them varies hum. Also, do NOT let the guitar "hear" the amp as it can feedback at frequencies above your hearing even. Do some "sniffing" by moving the guitar and the orientation around the area seeing if you can find hot spots of noise to avoid.
Sep 20, 2011 | Fender Musical Instruments Corporation...
My amp makes this static noise wich goes off as soon as i touch one of the strings or the metal part of the guitar cable. What can i do to make the noise disapear
This is a common problem... Make sure your amp is plugged into a three wire grounded receptacle. Keep the guitar away from magnetic fields of transformers in amps and effects units. Make sure you have a high quality guitar cable.
Sep 06, 2011 | Epiphone Les Paul Studio Electric Guitar
Hi, My Aria AS-690B Sinsonido has started making a strange crackling / low grumbling noise when plugged in. It still plays well, but the noise gets very much in the way. It sounds electronic. Any ideas...
First thing is to check that batteries are good. Next, verify your guitar cable is a good one... some are microphonic and the cable can actually insert noise into the signal. The plugs on cables can sometimes be noisy as they move while playing. Try to keep the guitar from "hearing" the amp as it can create feedback. Verify the amp itself isn't the source of the noise. Try a different guitar. The input of the amp is grounded by a contact when cable is removed, If there is a problem right in the input stage it can be masked. Plug only the guitar cable into the amp... Is ti quiet? If so make sure to try the first few suggestions. ALso be aware of other noise producers like fluorescent lights an dimmers... these generate electrical noise that sensitive guitars can pick up.
Apr 14, 2011 | Aria Sinsonido AS-100C
My warlock makes this horrible noise as i plug in the cord. I don' have ANY idea why. I've been messing around with it and still nothing has worked out. It makes the sound as if my amp is turned all the...
If the noise is a pop or click, that's normal. Any other sound could be caused by too long a cord, which will produce noise while on the floor.
If it's not the cord, then you most likely have something wrong with the wiring inside the guitar. Have a luthier (guitar builder and technician) look at it, and s/he should be able to fix the problem.
Hope that helps!
Nov 21, 2010 | B.C. Rich Nt Warlock Electric Guitar
Output jack
Have you tried another cable between amp and guitar? Usually the cable goes bad first. Have you tried another amp or possibly tried another guitar on your rig? If this still indicates that your guitar's Standard 1/4" TS Jack is noisy, remove the oval cover over the jack and check the solder joints for the wiring. Follow the wires back to the tone and volume pots and check those solder joints. If everything is secure...Plug in, power up and check for noise while turning the volume pots stop to stop. If the pots make a scratching noise, shut down rig and unplug the guitar. Get a can of spray contact cleaner with a small extension tube (available at electronic shops) to spray in the pots while turning them. (May have to remove pots fom the guitar to get at small openings on side of pot can.) Spray jack and test for noise. Jack STILL
noisy...If you can solder...unwire old jack, remove from guitar, take to electronic shop, match to Standard 1/4" TS Jack, install in guitar, resolder wire connections and test. If you cannot solder...take guitar to
a reputable shop or dealer that does this repair. Good Luck! P.S. The
spray contact cleaner can be used on the amp jack, pots and switches
too...just make sure the amp is unplugged from the power supply before
doing any spraying.
Jul 14, 2010 | B.C. Rich Nt Warlock Electric Guitar
When I turn on my fender hot rod deluxe 40W, even before plugging in my guitar, it crakles and makes noises constantly. I've had it for over 5 years and I play it maybe 1 hour a week. Is it a tubes issue?...
This is likely either a tube issue OR one with capacitors.
You need to characterize the loudness of the noises versus the settings of the controls as part of troubleshooting...
You can try tapping each tube with a pencil to see if one in failure will reveal itself.
Jun 16, 2010 | Fender Hot Rod Deluxe Guitar Combo...
When plug in guitar to amp, there is either no
Try a different guitar and cord. If still problem, give the amp a bump without guitar plugged in. If amp makes noise, there is an intermittent internal connection,
Paul
Jun 07, 2009 | Roland MMP-2 2-Channel Amplifier
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 | Music
MY FENDER GUITAR AMPLIFIER IS MAKING A HUMMING BUZZING NOISE
Not sure yet, but before considering a fault with the amp, does it only make this humming noise when not plugged into the guitar? I am thinking that the cable might be faulty.
If it while the cable is plugged in the guitar, does the humming disappear when you turn the volume control(s) down on the guitar? I am thinking that one or pickups may be faulty.
Sep 14, 2008 | Audio Players & Recorders
Behringer EUROPOWER EP2500 Amplifier Logo
225 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
