Question about Sanyo DRW-500 DVD Recorder
Does not recognise either new disc or pre recorded disc dvd or cd
When you insert a disc and close the tray it starts saying it's loading but then opens the tray. when you turn the power off it open the tray as it shuts down.
    President:
  • 563 Answers
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the player that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 22, 2009
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
DVD disc tray keeps popping out
I had mine for 2 years and within the first 12 months the tray would not always pop out when I wanted it to. Then finally the machine would not recognise the disc type. Its in getting fixed but although the dvd drive and associated pcb have been replaced the guy says it still can't recognise the dvd disc type. Still trying to work it out.
Mar 25, 2009 | LG DVB418 DVD Player
Alba DVD recorder won't recognise any discs
The Alba DVD recorder may not recognise any disc due to one or two of the following reason.
1, the optical pick up (lence) may be dirty or may have gone bad.
2, the cable which connects the optical pick up to the circult panel board may have go borken.
Jan 04, 2009 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
CyberHome DVD Recorder - DVR1600 says No disc when there is a disc
Hi! Pick a jhonson's bud -- dip it into the lens cleaner solution -- rub gently on the lens both clockwise and anticlockwsie -- leave it to dry -- cover up -- run the machine.. but be careful -- don't touch the lens with ur finger and dont try to rub roughly -- lens may go forever. still if the problem remains , replace the lens. chhoton
Aug 21, 2007 | Cyberhome DVD Recorder - DVR1600
Disc loading problem
disk draw timing is probably out ( gear or mechanism jumped out of time
Jan 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Sanyo DRW-500 DVD Recorder Logo
275 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
