Question about Acer Aspire One AOA150-1504 Netbook
How do i open aspire one to check hard drive?
Dropped netbook and believe i shook hard drive loose.  (will not boot up and asks for disk but no disk drive)  want to get in there to check but am afraid of hurting something, also can't figure out how to get this thing apart.  maybe you have a diagram?
  • 91 Answers
Well..... i understand that your notebook has dropped and not able to boot with an error.. to isolate this issue i strongly recommend to the steps given below 1. restart the noteboot or press the power button to restart...... 2.Now press the function key F2 this takes you to BIOS which u can see the options in a blue screen. 3. Here in BIOS mode you need to perform HDD self test. If the test failed to examine the hard drive then you need to replace the hard drive.
Hope this could help u...... For further quries give me reply...
Posted on Jul 22, 2009
My acer aspire one netbook AOD257 keeps telling me no bootable device insert boot disk
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 17, 2012 | Acer Aspire One Netbook 8.9" Notebook
Please help me..i have a aspire one d260 netbook..the problem is bootmgr is missing..it has no cd drive and i dont have a external cd drive to use.. how can i fix it using only a usb flash drive..how can...
You might have to take it to the shop. Lesson learned. Never buy a computer without a CD Drive because one day the system is going to croak.You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 29, 2012 | Acer Aspire One D260 Netbook
Verifying dma pool data
This issue can be caused by any of the below reasons.
i. Corrupt boot files on the computer.
ii. Settings for hard disk drive are not correct.
iii. Floppy diskette or CD in computer causing issue.
iv. Boot devices not set properly.
v. Connections loose or disconnected.
vi. Bad Hard disk drive or other bad hardware
Check if the Hard Drive Automatic Detection in BIOS (Basic Input/output System) is enabled and save the settings and check if it works
check all leads from motherboard to hard drive make sure tey have secure dust free connections if its a 40 pin flat ribbon ide it will be the first to fail
hope it helps
Mar 23, 2012 | Acer Aspire™ T180 PC Desktop
Acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
Jan 10, 2012 | Acer Computers & Internet
How do reset my acer aspire one netbook back to factory default
Hello, it appears this unit is a 160 Gb hard disk with windows xp installed. press the ALT + F10 keys when you boot up the laptop and see the Asus logo. If you still have a restore partition on the netbook this will get you into the restore process, if not you will need to reinstall from a portable cd drive and factory cd discs.
Mar 08, 2011 | Acer Aspire One Netbook
I have dropped my acer aspire one netbook and now the following message keeps being displayed upon reboot. Intel UNDI. PXE-2.1 (Build 082) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE...
By the sound of the message, your hard drive broke when you dropped it. You can open the hard drive door (should be on the bottom help in by a screw) and re-seat the connector to see if it just got loose. You will likely have to purchase a new hard drive and reinstall your operating system. If there is data you really need off the hard drive you can call a data recovery service to try and salvage what's left on the hard drive, but it will likely cost in the hundreds of dollars range.
Hope this helps, and thank you for using FixYa!
Jan 20, 2011 | Acer Aspire One PC Notebook
For Acer Aspire One Net Book Check cable connection..! PXE-MOF: Exiting Intel PXE ROM No bootable devise-- insert boot disk and press any key
Your netbook is trying to boot from your Lan/Ethernet connection since It can find no working hard drive to boot from. This usually means that your hard drive has failed.
Also remember that your netbook will try to boot from other drive types including your SD card, USB Memory Stick and even a Magic Jack if you have one inserted in the flash memory slot or USB slot while rebooting the PC.
Many people have mistakenly assumed that their Netbook is messed up because they forget to remove all flash and memory sticks before rebooting.
Oct 31, 2010 | Acer Aspire One PC Notebook
I have a Acer Aspire One Netbook it has come up with a NTLDR is missing i have restart it put it comes up the same can you help me plz
Causes:
   1. Computer is booting from a non-bootable source.
   2. Computer hard disk drive is not properly setup in BIOS.
   3. Corrupt NTLDR and/or NTDETECT.COM file.
   4. Misconfiguration with the boot.ini file.
   5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
   6. New hard disk drive being added.
   7. Corrupt boot sector / master boot record.
   8. Seriously corrupted version of Windows 2000 or Windows XP.
   9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions are here: http://www.computerhope.com/issues/ch000465.htm
Let me know if you need some help
Sep 11, 2010 | Acer Aspire One Netbook 8.9" Notebook
Need an manual every time i turn computeron a message asks for a boot disk!
The computer is asking for a boot disk because it cannot see your hard drive. Check the bios to be sure that the BIOS is recognizing your hard disk. If it is, then you may have a hard disk failure or a motherboard failure.
If you go out to ASUS's website you can download a user manual by putting in your model number, etc...
Jan 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
Media test failure, No bootable device, insert boot disk.
Media test failure, no bootable device error message means the hard disk has failed, therefore cannot boot up.
If reseating the hard drive doesn't fix your problem then replace the faulty drive and install Windows on the new drive to get the computer operational again.
May 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One AOA150-1504 Netbook Logo
924 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
