Question about Adobe Photoshop 7.0 (321115627)
Importing pictures into photoshop organizer
How to import email pictures into organizer?
  • 18 Answers
Steps
1. right click the picture you want to import
2. select "save target as" option.
3. select the target you want to save and click ok
Posted on Jul 10, 2008
I am using Photoshop Elements 12, and it will not let me import any photos into it. Can you please help me? Thanks.
Two options might help:
  1. Turn off Media Analysis using Edit > Preferences > Media Analysis then uncheck all check boxes there.
  2. Try repairing the catalog using the Repair function of the Catalog Manager.
    1. Make sure Photoshop Elements Editor is closed.
    2. Open the Catalog Manager.
    3. In the Catalog Manager, select the catalog that you want to repair.
    4. Click Repair.
    5. When the Elements Organizer finishes checking your catalog for errors, select Re-index Visual Similarity Data and then click Repair or Repair Anyway.
    Hope this helps
Apr 13, 2015 | Adobe Photoshop Elements 12 - Mac/Windows
Can't get pictures into photoshop
There are several ways to open images in Photoshop. Try any of these:
  1. File>Open (browse for and select file)
  2. File>Place
  3. Drag and drop image onto Photoshop application icon
  4. Drag and drop image onto Photoshop's control bar
For more options, see Adobe's help files at http://helpx.adobe.com/en/photoshop/using/creating-opening-importing-images.html
Creating opening and importing images
Apr 20, 2014 | Adobe Photoshop 7.0 for PC
Getting pictures from camera into photo shop
Plug the camera into your computer. Locate the file and just drag it into Photoshop.
Apr 20, 2014 | Adobe Photoshop CS2 for PC
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
Adobe photoshop want to import photos
if its the free trial download for like photoshop, then if your running on windows, open up control panel and click 'Change or Uninstall Program' then find Photoshop and right click and click uninstall
Apr 10, 2010 | Adobe Photoshop CS2 for PC
How to scan photos in
Well if you are using an application similar to PhotoShop Elements X.X
You go to "File" and look for "import" or "Get Pictures" > "From files and folders"
Select the pictures you want and import them.
If touy are trying to download from the camera, go to File > Get from > Camera and import from there.
Don
Feb 11, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Cannot see pictures in organizer only squares with hourglasses
I went to CNET and did a search for a program that can undelete files even from the recycing bin. It worked like a charm!!! I think it is by Glary utilities.
May 19, 2009 | Adobe Photoshop Elements 6: Windows
Customizing an Invoice in QuickBooks Pro 2007 for Mac
From Photoshop, save it as a Photoshop PDF and import it that way. You can customize it as much as you want.
Apr 27, 2009 | Intuit QuickBooks® Pro 2007 Full Version...
Importing an email address
Hello there!
I suggest that you do one thing first, connect your camera with a USB cable to your laptop or pc. then thru USB cable you may copy the photos or import them from the camera to the pc. And there you go, you can send the pictures to your friends visa Email!
Feb 17, 2009 | Kodak EasyShare C613 Digital Camera
Importing TIF files in Adobe Designer
than change you resolution DPI
as you increase your DPI you will get batter quility but haveing quit more size than previous tif,
so try & funn,
THNX
May 16, 2008 | Adobe Photoshop 7.0 for PC
Adobe Photoshop 7.0 (321115627) Logo
369 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
