Question about Samsung BL103 Digital Camera
Lens is stuck and it wont turn on
My samsung bl103's lens are stuck out, and when i try to turn it on it buzzes/beeps but nothing happens. i tried chaing the batteries, the problem continues.
I need my camera TONIGHT for a concert! help!?
Same thing is happening to my camera. If you bought it with in a year call samsung, their customer service and warranty service is great. If you are not sure when you bought it, they can check with the serial number I believe, but most of these cameras were available around black friday last year. Have the camera with you, go through the process the representative tells you to do and as whit my camera they'll determine they can't troubleshoot over the phone and send you what ammounts to an Return Authorization # (RA#). The whole call will probably take about 10 minutes at most.
Gool Luck
Posted on Aug 11, 2009
The lens wont go in all the way and when i try to turn it on it make a bunch of beeping nosie and the screen is blank. what should i do???
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 29, 2010 | Samsung BL103 Digital Camera
My Samsung BL103 was dropped by my daughter and now the camera won't turn on and the lens is stuck in the out position.
There is Lens adjustment out you need to fix this problem by opening your set and Lens block to readjust.after that it will work.care fully handel this.
Oct 30, 2010 | Samsung BL103 Digital Camera
Beeps three times but does not come on, changed batteries, zoom stuck... not going back in
I found this answer on another forum. I giggled the lens as it was stuck out and then pushed the power button to guide it back closed. Then I gave it a soft whack on my palm when the lens was closed. I think I had a piece of sand stuck where the lens goes in and out. I also made sure that the battery type was Ni-Mh instead of alkaline on the menu. This is a recurring problem with Samsung cameras.
Jul 22, 2010 | Samsung BL103 Digital Camera
Lens stuc and makes beep sound
I had the same problem and my brother just wiggled the lens shut carefully while turning the power on at the same time , it took about 5 tries and finally had the lens was all the way back in place and it works great.It was just the lens was stuck open and would not start up like that I guess. better then junkin it.
Sep 01, 2009 | Samsung BL103 Digital Camera
Samsung bl103 will turn on and beep 3 times then pauses and beeps 3 times again and the lens is stuck in the out position
Mine does the same thing. I open the battery door and close it back up. Then I push the power button and the lens will retract. When I turn it on afterwards it works fine. Mine does this quite often.
Jul 22, 2009 | Cameras
Today, I was using it. Turned it off for a whle, went to ues it again & it wouldnt turn on, the power light was on & three beeps came out of my camera! It wont turn off until I take the battery...
Most probably the lens problem, it got stuck or it's damaged. Try to gently pull out the lens to see is it only got stuck or take it to service
Jun 23, 2009 | Samsung L100 Digital Camera
Samsung Digimax S600 is stucked in off position
I've had this with a diff model of Samsumg (V10). The problem with mine was that the lens wasn't opening, which was causing the beeping. I held the camera with lens facing down and when I pressed the power button I lightly tapped the camera against the palm of my other hand. The lens extracted.
I have more problems with the lens now but that may have something to do with me dropping it later:(
Aug 12, 2008 | Samsung Digimax S600 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Samsung BL103 Digital Camera Logo
307 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
