Question about Honeywell Heating & Cooling
My old 1955 honeywell furance stay on all year round. How do I shut it off?
  • 867 Answers
It needs to have a regular wall type switch wired into its 110 volt supply. or just pop the circuit breaker for it in the fuse box.
Posted on Jul 22, 2009
My totaline thermostat model #p474-0100-a the backlight is staying on and when the furance is running after only a couple of minutes it shuts off and my furance shuts down .
Multiple issues that are not related. If the pilot light goes out then the thermocouple might be bad. If the pilot ignites the gas and everything shuts off, it sounds like the over temperature sensors are detecting heat in excess of what is allowed in the firebox. The thermostat issue has nothing to do with this.
Nov 19, 2014 | Heating & Cooling
I have a Rheem heat pump and a Honeywell thermostat. I let my air filters get too dirty, and they restricted the air flow so the system shut off. I have replaced the air filters but the upstairs doesn't...
You may need to replace the furances high limit switch. This is located abvove the burrners with the top frot door off. It has two wires going into it. The furance probably was cycling on this switch which automatically resets it self. The thermal dics wears out and starts to trip at lower temperatures. You can temporally jump across the switch and check the furances opreration but do not leave this switch jumperd because it is a safty.
Feb 06, 2011 | Honeywell Heating & Cooling
How do i change an old style honeywell room stat
Shut the furnace off for starters. Remove the old Thermostat. As you remove each wire write down what terminal it wen to.
Example:
Red wire usually goes to R-Power
Green Wire usually goes to G-Fan
White usually goes to W-Heat
Blue or Yellow usually goes to Y-Cool
Jan 04, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell round thermostat Model #T87F continuously running
you either have 2 thermostat wires bare and touching or a zone valve stuck open
Feb 28, 2009 | Honeywell Programmable Thermostat Heater
BOUGHT AND REPLACED A HONEYWELL ROUND THERMOSTAT AND THE HEAT WILL GO ON BUT WILL NOT SHUT ITSELF OFF WHEN THE TEMPERATURE GETS TO THERE. IT KEEPS RUNNING TILL I SHUT THE THERMOSTAT OFF. I FOLLOWED THE...
look at the old thermostat and in the middle of it theres a arrow that is pointing at numbers that is called a heat anticipator. then on the new thermostat make sure that its set the same.
Feb 21, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Weather King Furance
Hi Cableman. Any 24-36" thermocouple wll work and can be found at your local hardware store.
Hope this helps,
RepairUSA
Nov 05, 2007 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
