Question about Kyocera Copystar CS-1820 Black and White Copier
Pressed the RESET button and machine turned off. Now I can't get it to turn back on.
  • 1,294 Answers
Unplugged the power cord,open the fron door,wait few sec.,plugged,closed the door start your copier.If cannot turn On check the main power unit fuses.
Posted on Aug 02, 2009
Reset c0500
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Aug 08, 2016 | Office Equipment & Supplies
How can I reset eror code CO 500 on konica minolta copier DI 2510
Aug 08, 2016 | Konica Minolta Di2510 Di251 Di250 Di2010...
Bizhub c352 reset cod?
Trouble Reset
Turn off the machine, Now press "utility/Counter" Now turn the machine ON.Keep the button pressed. Trouble reset button will appear on screen, press it and restart the machine.
May 28, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How to reset c3803 code bizhub750
If the code comes back, you need a Fusing unit ( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
1. Turn ON the main power switch (SW1).
2. With the Utility/Counter button pressed, turn ON the power switch (SW2).
3. Press [Trouble reset] to release a trouble with [OK] displayed.
4. Turn OFF and ON the power switch (SW2).
Jan 08, 2014 | Konica Minolta bizhub 750
ERORR C0500
Sep 26, 2013 | Konica Minolta Office Equipment & Supplies
C3451
C-3451 on the bizhub range indicates Heat. Heater Trouble.
This is not resettable in the normal manner.
To reset, turn machine off (switch insde front door, bottom left)
Turn back on, but hold down the UTILITY button while doing so. Keep UTILITY pressed until you get a message on the display saying 'trouble reset'. Remove minger from UTILITY and touch 'trouble reset'.
Now turn the machine off again, same switch as before.
Turn back on normally and see if it warms up and you get a green button.
I have had a few machines do this code for no apparent reason. I've had others which required a new fuser unit.
Hope yours is the former.
Good luck
Regards
Tam
Mar 23, 2010 | Konica Minolta bizhub C250 All-In-One...
Error9 what does this mean
turn Programswitch to ‘OFF’ -
press first 2 buttons (1 and 2) Keep it pressed turn programswitch 1 klik to the left (against the klok)
all LED’s lights up.
realise the buttons
turn progam switch to off
youre machine is now reset
if problem comes back, carbon brusches on the motor are defect.
Jan 03, 2010 | AEG Washing Machines
Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
Oct 19, 2008 | Konica Minolta bizhub C250 All-In-One...
It turns off
The e1 code is a demand to clean the filter. It means the unit has been running for 720 hours. It does not mean anything is broken...unless it hasn't been running for 720 hours. That would mean the "clean the filter" timer is broken! There are 2 reset methods.
1) Unplug the machine. Hold down the power button while plugging it back in and wait until it beeps (for about 5 seconds). Let go of the power button. Unplug the machine again, then plug it in and try to use it as an air conditioner.
2) Unplug the machine. Hold down the Mode button while plugging it back in. Keep the mode button pressed until it beeps (for about 3 seconds). Let go of the mode button. The machine will start. Turn it off by pressing the power button. Resume trying to use it as an air conditioner.
If neither of these work, the "clean the filter" timer is broken and needs replacing.
Jul 23, 2008 | Sharp AF-S100FX Comfort Touch Air...
Water fills in and out during the whole cycle but no spin
unplug the machine for 60 sec or more then plug back in this may help this resets the computer good luck
Dec 17, 2007 | Malber P21 Front Load Washer
Kyocera Copystar CS-1820 Black and White Copier Logo
176 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
