The above ovens don't get hot, the flame is on but doesn't flare up to get oven up to temperature
The FFD or it might be called an FSD in cannons case is faulty it needs replacing. The fault is that it is not forcing open the valve to let teh gas come through when it gets hot... These are easy to fit if you know what your doing .... Be careful it is a corgi man job. Flame faliure device or flame saftey device.... 100 %
Grill wont work..seems to be locked...do i force it????
I also have a Cannon Double Oven, same problem, upper oven seems to work ok (so far), but the lower oven just stays on a low flame (like initial ignition), but will not rise to the required gas mark.
i have the same fault, can i replace this or does it need to be replaced by a pro. as i can buy the part online, many thanks Tony
cannon stratford - flame in oven is on but won't increase as I turn dial. grill and hobs are fine.
