Question about Avaya Lucent Partner 616 Phone
Voice Mail Problems
When someone calls in on the night service ring and pushes in an extension...it does not go to the extension they all stay at the main phone voice mail. How do I fix this on an avaya partner phone system?
  • Vitaly Kagan
    Vitaly Kagan May 11, 2010
    can you be more specific?
  • Anonymous May 11, 2010
    Well, the night selector codes may not be set correctly. What happens now when you casll at night? Does it go to the night AA? Or a mailbox? Spell out exactly what is happening so we can help you quicker.
You will want to go into the night attendant and check the selector codes. What voicemail do you have?
When you dial into voicemail, oicemail Vicky answers and says, "welcome to ....." what is the rest?
Posted on Dec 31, 2009
Calls dont go to voicemail
The "Recall" Destination of that phone needs to be voicemail. Usually 2500. You have to go inti database programming to make that happen.
Sep 08, 2014 | Inter-Tel Lands Phones
Avaya partner acs
Are these call from the outside? If so, it sounds like the Night Service is turned on. If not and these are extension calls then the Do Not Disturb is probably on.
Jul 23, 2014 | Avaya Eurostyle 18D Corded Phone
Canceling call forwarding from one extention to another
On the extension that is forwarding use Feature #4 to cancel the call forwarding unless it is programmed under the capabilities section in programming. This will require someone with programming ability to make the forwarding change back to the voice mail access number.
May 01, 2013 | NorStar M7310 Corded Phone
Voice mail not working
Contact your Service Customer Supporter by dialling your respective Service Company Customer Care(Airtel/Aircel/etc..) or Contact your nearby dealer. Actually its a problem which is related to your sim.
Jul 24, 2012 | Panasonic KX-T7440
I cant change the voice mail
When you say voice mail, do you mean your personal vmail box or the AutoAttendant? If so you'll need to login to the 998 mailbox and modify the "Custom Service" prompts (menu# 5-3). NOw as far as the ringing goes, you might try doing an extension data clear procedure by doing Intercom -> *790 (I think it's Intercom 7900 on the older systems). Otherwise you should call a local Panasonic Dealer for a service call. Contact me offline for a referral.
Sep 02, 2009 | Panasonic KX-T7630 Corded Phone
One of our office phones is set up for voice mail yet the phone rings continuously. It won't offer the caller voice mail. Any suggestions?
You need to go into system programming and set that extension to "Forward no answer" to the extension of the voicemail.
If you dont know what that means, I would call someone in, as you can ruin your system by doing the wrong things.
Aug 05, 2009 | Nortel Lands Phones
When someone calls me the ringer on the phone does not ring.I do not know how to turn the ringer back on. Also when someone tries to leave me a message the answering machine does not record the message....
On the phone not ringing, just push the volume up button while the phone is not in use, that should adjust the ringer volume. As for the message saying that calls are being routed to an automatic message sertvice, that sounds like a voice mail offering from your service provider, not the phone. Uniden phones have a default greeting that says "Hello, no one is availible to take your call, please leave a message after the tone" Contact your service provider and find out if you have voice mail service on your line. If you do and want to use the answering machine on your phone, you will need the service provider to allow for more rings before the voice mail service takes the call.
Mar 16, 2009 | Uniden 5.8GHz Dual Cordless Phone
EXTENSIONS DON'T RING IN NIGHT MODE
A solution depends on what you are trying to achieve. Usually they are set up this way so when everyone has gone home the calls go to the voice processing system. If you have people working later, it would be easy to make night mode start later via system programming, which is program number 102 .
Feb 05, 2008 | Panasonic KX-T7453 Corded Phone
Answering machine
Your phone can be programmed to transfer a call to different places and have different rules for day-ring mode and night-ring mode.
Sounds like what you want to do is change your phone to transfer to another extension instead of your voice mail box. This would in effect eliminate your voice mail box because a call would never automatically be sent to it unless you use (and program correctly) night mode.
Your phone model type does not help resolve this. You can have this phone on different Panasonic phone systems. You will need to determine which phone system you have and locate "programming" manual for the specific system (not a user guide)
There should be a section or option called "no-answer forward", "forward timer", "forward extension" etc...
Dec 13, 2007 | Panasonic KX-T7630 Corded Phone
Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
Nov 21, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Lands Phones Logo
213 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
