Question about Garmin StreetPilot C330 GPS Receiver
How do I open the case of a Garmin c330? Please
How do I open the case of a Garmin c330? The display is beginning to fail, tap the unit and it sometimes returns. I think it is a dirty connector. Thanks for any assistance
To open a Garmin c330 gently pry the silver front cover off by starting at the Garmin Logo location. A thin blade or small screw driver will work well. The silver cover has molded snap-in clips that pop out from the main case. Once the silver cover is off, remove the 4 screws and the case will open. My display was not working, I fixed the problem by adjusting the display's ribbon cable at its connector.
Posted on Jul 23, 2009
My Garmin C330 won't turn on.
This is likely a failed battery.
The battery on these units is not user-replaceable (soldered to the PCB) and must be returned to Garmin for repair.
CLICK HERE to see more about their FLAT RATE repair service.
Your StreetPilot C330 is listed as a $79 flat rate repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 17, 2010 | Garmin StreetPilot C330 GPS Receiver
It is not aligned with the keys or letter or icons
Try a screen calibration. To recalibrate your c-Series touch screen follow these steps:
1. Begin with the unit turned OFF and unplugged from a power source.
2. Power the unit ON, continue to hold the Power button for 1 minute.
3. A screen will display instructing you to Press dot in the lower left corner.
4. Release the Power button and touch the sequence of dots until your unit displays, Calibration complete.
5. Your unit should now function normally.
Sep 20, 2009 | Garmin StreetPilot C330 GPS Receiver
Need battery for street pilot c330
THis battery will work in your C330 Garmin. I have had it in my unit for 3 years now without any issues.
http://www.etronicspal.com/132805.html
Just open the unit and splice the wires, and use some electrical tape. Good as new.
Jul 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 has problem finding gps signal and tracking sattilite.
power off the unit first then power on then go to map screen then tap the signal icon bar then wait for your unit to track signal then when you see 5 signal go back to the map screen and check the signal icon and then if there is a firmware update for your unit try to download it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 09, 2009 | Garmin StreetPilot C330 GPS Receiver
Display image has shifted, difficult to use
ok, first you will have to unplug the power and usb cables to remove external power. Secondly, place your thumbnail in the groove located under the Garmin logo on the face plate and gently pull off the face plate. Next, press the reset button for three seconds. Finally, connect the c330 to a power source using the power cable. the c330 should automatically turn back on and operate normally.
Please rate my response and have a wonderful nite.
Mar 10, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 antenna connector has fallen into the gps
Pry off the colored faceplate around the screen. Underneath will be four screws. Remove them and open the unit up. You should be abe to access the inside of the unit to figure out a way to reattatch the connector. I have not had to do this but I have opened a couple up to replace displays. The hardest thing is getting the thing back together due to how the antenna mounts (poorly). Just open it slowly and visualize how it goes back in. I have no advice on actually fixing your issue, just on how to get in to look around.
Dec 17, 2008 | Garmin StreetPilot C330 GPS Receiver
Update older garmin c330 purchased march 2006
check with GARMIN we have no clue as to if OLD units can be updated . Google GARMIN UPDATING
Feb 05, 2018 | Garmin StreetPilot C330 GPS Receiver
Cannot download from the disc to my garmin c330
Hi, bit confused.
If your using Disc's, then download is a different procedure.???
Assuming disc's
Just copy from the disc's , say off the desktop, you can put them on there to use it, then right click and copy the correct files,
Go to my computer, go to the nuvi drive, open up the nuvi folder, paste it to the correct folder, restart it.
If the maps are there, then tap menu, map info, tick boxes
serial needed and Unit I.D. to activate
unit I.D., menu-tools-system-about
If downloading, jack it to Pc, run download again,
Through your account @ Garmin.
Hope this helps
Regards.
Sep 03, 2008 | Garmin StreetPilot c340 GPS Receiver
Failure to acquire satellite
To reset the unit, pry off the silver faceplate.
Turn the unit on using the power button on the right side.
Press the reset button that was hidden behind the face plate.
The GPS unit should restart, and display its software version.
Make a note of the software version in case you have to call customer service.
To acquire satellites make sure the GPS has a clear view of the sky.
For Garmin customer service, call 800-800-1020.
You can also go to this link for complete customer service info:
Garmin Customer Service
Good luck, please rate this response favorably.
Jan 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
301 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
