Question about Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
Can't get Motorola 250 case open
The case is solid, I can't get it open to change batteries. What is the trick?
  • Anonymous Mar 21, 2014
    having trouble opening the case to change my batteries
  • Motorola Master
  • 1,654 Answers
The black "U" shaped sides are attached to the back portion. It is one piece. It slides down and off of the radio.
Posted on Jul 22, 2009
Replace battery on motorola talkabout 250
The U-Shaped sides are connected to the back. Pull down on the U-Shaped sides and this entire part will slide down and off the radio to expose the battery compartment.
Jan 22, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
Change battery
Grasp and pull down on the black U-shaped sides of the radio and this section along with the back half of the radio will slide down and off the radio to expose the battery compartment.
Best regards.
Jan 07, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
How to open bluetooth headset motorola H730 to change the battery
Jorge
The battery is not replaceable by consumerrs. Mark
Motorola Support
Sep 24, 2012 | Motorola Mobility H730 Bluetooth Headset
How do you change batteries on a motorola 250 talkabout phone
The U-shaped sides are attached to the back battery door on this style radio. Grasp the U-shaped sides and pull down. The entire section will slide down and off the radio.
Best regards.
Dec 20, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
I need to know how to open it to replace the batteries....thanks
The U-shaped bottom and back are one piece. Grasp the radio by the sides and pull straight down to remove. In most cases this section of the radio is black in color.
Best regards.
Nov 28, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
When I press the push to talk button on my Motorola talkabout 250 there is a constant beeping noise and I cannot transmit
Generally a constant beep is the sign of a low or bad battery. However, it is noted the TalkAbout 250 is operated with AA batteries, and it is likely you have considered this and changed batteries. You might check your battery contacts, and clean them with a pencil eraser to assure they are making good connection. Otherwise, you may have a failing radio.
Best regards.
Nov 02, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
I don't know how to get to the battery
On the back of these GRMS radios, there is a latch at the bottom of the casing. Remove the belt clip by pushing it up, then release the latch at the bottom of the radio to open the battery compartment.
The battery door will flip up then pull it down and off. Reverse to replace and battery installation.
Oct 11, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Change battery???
If you are using the radio in the photo the TalkAbout 250, the battery cover is the black U-shaped bottom of the radio. It slides down and off the radio. It and the back (bottom half) of the radio are all one piece.
May 07, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
I can't find a download for the Motorola Talkabout 250 manual
Grasp the black bottom sides of the radio and tug it hard. No screws to loosen. The bottom slides off. The battery placement will be in there.
Apr 21, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
GP 360 Radio Charger
On a Motorola charger, when the battery is charging the light should be a constant red (or amber depending on the charger). When the charge cycle is complete the light will change to solid green. Sometimes the solid green time is brief, as the battery will begin to lose charge, and the charger will go back into trickle mode and change once again to red (or amber). In most cases, a flashing light indicates a problem, such as a bad or shorted battery, an incorrectly seated battery, dirty battery contacts, or a bad connection with the battery. (Note: Batteries last 18-24 months typically. Check your date code for the age of the battery.)
There were several chargers made for the GP360, including but not limited to a 60-minute charger, a 90-minute charger, a 10-hour trickle charger and a 6-unit gang charger which would be a rapid rate, either 60- or 90- minute. If you would supply your charger's model number we could tell you which one you have.
Nov 02, 2008 | Motorola HNN9628A Two-way Radio Battery
Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio Logo
274 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
