Question about Frigidaire Affinity ATF7000E Front Load Washer
Pressure sensor frigidaire front loading washer
My washer is giving me a E31 code. Pressure sensor not communicating with control board. Where is the pressure sensor? What am I looking for. Just trying to find out before I call service tech. thanks.
4 Suggested Answers
  • 1003 Answers
SOURCE: Frigidaire Washer - pressure sensor
I WOULD SAY REPLACE THE PRESSURE SENSOR IF BOTH CONTROL BOARDS HAVE BEEN REPLACED
THE MOST ECONOMICAL PART ASSOCIATED WITH THE CONTROL BOARDS ESPECIALLY AFTER HAVING ELECTRICAL PROBLEMS IS MORE THAN LIKELY THE PRESSURE SENSOR it may have BLOWN ALSO
Posted on Jan 31, 2008
SOURCE: I have a Frigidaire front load washer model FTF2140ES2 that will
The rubber around the door tore and the washer leaks bad.where do i find that part.
Posted on Jun 21, 2009
  • 2468 Answers
SOURCE: Frigidaire Affinity Front Load Washer ATF7000FSO,
you are absolutely correct,but this component is very easy to locate part#F- 17 on an inset drawing in a frigidaire manual and you will find it at the end of the pressure sensor tube used to fill the tub,there is a plastic tube off the tub going upwards towards the top and the other end is connected to what you are looking for: part# AP4298882 @ $45.00+ S+H
Posted on Apr 10, 2011
Loc error code Frigidaire frontloader
From the frigidaire site.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
Tip
Frigidaire Affinity Common Error Codes. (E4A, E9E, E56, E46 and more)
Hi.
This error codes apply to Frigidaire Affinity washers and dryers:
E11 - Fill time too long.
E13 - Water leak in tub, or air leak in air bell.
E14 - Reed switch.
E21 - Water not pumping out fast enough.
E23 - Drain pump relay on control board failed.
E24 - Drain pump relay on control board failed.
E31 - Pressure sensor not communicating with control board.
E35 - Pressure sensor indicates water overfill.
E41 - Control board indicates door switch is open.
E42 - Door remains locked after cycle is completed.
E43 - Control board problem
E44 - Control board problem.
E45 - Control board problem.
E46 - Control board problem.
E47 - Control board is sensing the door PTC circuit is open during spin.
E48 - Control board is sensing the door PTC circuit is closed.
E4A - Program Timeout Fault.
E52 - Bad signal from tacho generator.
E55 - Motor overheating.
E56 - High motor current.
E57 - High current on inverter.
E58 - High current on motor phase.
E59 - No tacho signal for 3 seconds.
E5A - High temperature on heat sink.
E5B - High temperature on heat sink.
E5C - High temperature on heat sink.
E5D - Communication problem.
E5E - Communication problem.
E5F - Communication problem.
E67 - Input voltage on microprocessor incorrect.
E75 - Water temperature sensor circuit (digital readout models only).
E76 - NTC temperature for the cold water valve over the limits
E95 - Communication error.
E9E -Voltage error.
EB1 - Incoming power frequency out of limits.
EB2 - incoming line voltage above 130 VAC.
EB3 - Incoming line voltage below 90 VAC.
EF1 - Clogged drain pump.
EF2 - Too much soap.
on Apr 09, 2010 | Frigidaire Affinity ATF7000ES Front Load...
E31
Hello Stephanie - If you are receiving error code E31, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
May 02, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
Error code 31
Hello Elizabeth - Typically error code E31 indicates that the pressure sensor is not communicating with the main control board. I would suggest contacting a professional to inspect the wiring between both parts. Depending if the wiring is defective or correct might have to replace the pressure sensor. If it does not correct the problem, the unit may possibly have a defective control board and will need replacing.
Oct 01, 2012 | Frigidaire ATF6000ES Front Load Washer
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
E14 Reed switch.
EF2 Too much soap.
Apr 22, 2017 | Frigidaire ATF6000ES Front Load Washer
Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E14 Reed switch.
EF2 To much soap.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
WAHING MACHINE ACTING UP
E31 ERROR MEANS. Pressure sensor not communicating with control board.
PLEASE CHECKOUT THE PRESSURE SENSOR.
Nov 09, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing machine error code on Frigidaire ATF6000E
No E20 on that model# Heremis a list of the codes
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E52 Bad signal from tacho generator. Refer to test (8)
E56 Highmotor current. Refer to test (9)
E57 High current on inverter. Refer to test (9)
E58 High current on motor phase. Refer to test (9)
E59 No tacho signal for 3 seconds. Refer to test (10)
E5A High temperature on heat sink. Test first if bad replace
speed control board.
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E75 Water temperature sensor circuit. Refer to test (12)
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
Mar 29, 2008 | Frigidaire ATF6000ES Front Load Washer
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Frigidaire Affinity ATF7000E Front Load Washer Logo
203 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
