Question about NetGear RangeMax WPN824 Router
I want to define tcp port for another program
I have sababaDC software and i want to define port for tcp and udp
the udp port is ok but in this program I will see all the time that tcp port is not define good and it is not acceseble
  • 854 Answers
Port Forwarding
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on Jul 23, 2009
XBOX ONE CANNOT CONNECT TO THE INTERNET THROUGH WIRELESS ROUTER
my first guess would be you need to open ports in your firewall.
  • port 88 (udp)
  • port 3074 (udp and tcp)
  • port 53 (udp and tcp)
  • port 80 (tcp)
  • port 500 (udp)
  • port 3544 (udp)
  • port 4500 (udp)
Jan 21, 2015 | Computers & Internet
Needs nat type open
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Regards
Tom
Jan 27, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
My nat is strict
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Regards
TOM
Jan 26, 2011 | Computers & Internet
How do i change the NAT type to open
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
regards
Tom
Jan 16, 2011 | Netopia 1 x 10/100Base-TX LAN, 1 x ADSL...
How do i change NAt type to a lower type
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 06, 2011 | Netopia 2247NWG-VGx Wireless Router...
Want to set nat type to open
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 05, 2011 | NetGear DGN2000 Wireless Router
Can I change the Nat type? Can't figure out how to change it from type 3?
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 03, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
How do I change my NAT setting?
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Dec 18, 2010 | Sony Playstation 3 (PS3) Console
PlayStation 3 keep getting nat type 3 when need type 2
Hi
I was having problems with my PS3 as well I did the following
updated firmwire
Also I assign static ip address on my PS3 and forward ports used by PS3 to static IP address of PS3 on routers firewall.
Ports used by PS3:
udp 3478
udp 3479
udp 3658
tcp.domain (port 53)
udp.domain (port 53)
tcp.http (port 80)
tcp.https (port 443)
udp.ssdp (port 1900)
tcp.amandaBackupInitiation (10080)
tcp.Jabber SSL/TLS (port 5223)
tcp.10075
tcp.10078
tcp.10079
If your still getting problems configure the PS3 to be in your DMZ.
DMZ will be under applications and gaming. Just look for that setting in your routers setup page and add your PS3 IP address to it.
Mar 15, 2010 | Linksys WRT160N Wireless Router
Port forewarding
Ok, this is very simple. All you need to know is what port number you need to forward and either TCP or UDP. (ex. 200 TCP)
Open an internet browser and enter 192.168.1.1
Enter your password.
Go to Applications and gaming. Look for port range forwarding.(by the way upgrade your firmware)
Under the program name, put what you want.
enter the numbers of the port from the start-end port option.
Select the protocol(TCP or UDP)
Select the Ip address of the programs computer and enable. (BE SURE TO SAVE BEFORE CHANGING THE PAGE)
Mar 23, 2008 | Linksys Wireless-G WRT54GS Router...
NetGear RangeMax WPN824 Router Logo
123 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
