Question about HP PL4260N 42 in. Plasma HDTV
Hp 42 plasma tv cptoh 0602 specs all the time and wavy sd video
Two problems.  First I'm getting specs on the screen white ones.  Mostly notable on dark colors on the screen.  Seems to be mostly on the lower third of the screen.
Second I have this odd issue that when watching standard def TV it will get al screwy and wavy looking.  The on screen menues do not do it.  If I change inputes and then go back or change to a station with HD and then go back it works for a little while.  It happens at random with no real noticable tigger to it.
Mine has done this from day one, appears to be a resolution problem. All I do is go to a HD channel let it tune in and then go back the the SD channel and don't have to worry about it until next time the power has cycled.
Posted on Jan 17, 2010
Hi! I have a 2006 HP High Def Plasma TV model CPTOH-0602, serial CNH6131576. It lost picture, I can hear sound. Wonder what couls be the problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 09, 2014 | HP Televison & Video
Picture just went out on my tv but I still have sound
I have the same problem with my HP PL4260N 42" Plasma HDTV serial # CNH6141988, model # CPTOH-0602. I have perfect sound and can change channels still with sound but NO PICTURE. I am a consumer with a question that need the advise of an expert.
Apr 17, 2013 | HP PL4260N 42 in. Plasma HDTV
I replaced the module on YSUS board and replaced the FS2 fuse on hp cptoh-0602 plazma tv. TV worked great for about 2 hrs of usage time. however, while i was changing the channal few days later since...
Usually, when you replace Y-sustain board, for older plasma, they suggest to replace both Ydrive board (up and low). And sometimes, Z-sustaint.
Im not sure your are an expertise in this matter so be very careful when you open a TV because hasardous voltages can kill you in the worst escenario.
If you are not, don't work on your TV. It will be your sole responsibility.
Check ships on Y drive board (both board are installed on the right side of Y-sustain. They have square black ships that used to get bad. If they don't have aluminum cooler on them, you can see if they are burned or have holes on them. Old plasmas use to have issues with those boards. Before you installed the Y Sustain you should check Ydrive boards. Maybe you damage the Y Sustain because the Y drives weren't good.
Try to replace the fuse, disconnect the Ydrive from Y Sustain, turn on TV and check for voltages on Y sustain (panel has a sticker with each voltage). Hope you didn't damage Y sustain and can find Ydrive board to fix your TV.
And REMEMBER, you can kill yourself when you work on TVs.
Sep 26, 2011 | HP PL4260N 42 in. Plasma HDTV
My picture is flickering but there the sound is
Did you try buying a new HDMI cable? You can also try some of the solutions in the post called "Hp 42 plasma tv cptoh 0602 I get sound but no picture."
Dec 31, 2009 | HP PL4260N 42 in. Plasma HDTV
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Hp 42in plasma tv
There is some voltages that need adjusted in your tv and possibly the z sustain board needs replaced if the voltage adjustment doesn't fix it.
Dec 10, 2007 | HP PL4245N 42 in. HD-Ready Plasma...
White speckly 'snow' on screen
y sustain board needs adjusting or replacing
Oct 10, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Negative looking white screen picture
this tv has many problems in the scan converter/hyper bd. the wavy picture is very common the problem with the white not so much. However, I have seen them cause many odd looking video distortions and I suspect this is where your problem is. The part is usually kind of high, 250 + Labor i'd guess. If you get it somebody good they can probably repair the bd rather than replace it and save you some money. Either way i'd plan on 300-400
Apr 24, 2007 | Toshiba 42H81 42" Rear Projection...
HP PL4260N 42 in. Plasma HDTV Logo
1,215 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
