Question about Dell Latitude D610 Notebook
Can't access the web
I have a Dell Latitude C600 that recognizes my wired LAN but won't connect to the internet. I have other computers that access the LAN fine and browse the web fine. The Latitude is running Windows 2000 Pro.
    Sergeant:
  • 175 Answers
Check LAN IP configuration properly, also check Gateway and DNS configuration.
Try to Ping your local host.
Start>Run>Cmd enter ipconfig/all and check your ip configuration.
Also check your server ip configuration.
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread with the results of your work.
Regards;
Hassan
Posted on Jul 22, 2009
  • 244 Answers
Check the IP address, Gateway and DNS values.
There is something wrong there.
The best way is to copy the value from the internet connection from another computer, and change the last digit on the IP address only.
Please don't forget to rate this answer if it helps
Dell latitude wont read 256 megs of ram only 128
The c600 can handle up to 512MB of RAM, so it's likely one of your RAM sticks is bad or not seated correctly. Are you using two 128MB sticks? Remove the stick from the second slot and turn on the computer with only one stick installed, and see if the RAM is recognized. Then take that RAM out and try the computer with only the other RAM stick -- if either is not recognized, that stick is bad.
If both are recognized, try reinstalling both RAM sticks and see if the computer will recognize them. If not, make sure they are both seated properly. You may have a problem with the second RAM slot if it is still not recognized. If you have access to other RAM, try that too and see if it is recognized.
Jul 27, 2010 | Dell Latitude C600 Notebook
Dell latitude cp laptop how do you make it wireless for the internet
All laptops have inbuilt wireless network cards. You would need to have a wireless access point which has internet connectivity at your home or office. If available, you need to search for the wireless network and get connected. Some networks are secured so you would have to contact the administrator for the key.
Jul 22, 2010 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Can i connect wireless internet on my Dell Latitude?
if it's a tower... you'll need a linksys pci wireless card... and a linksys router... install the drivers first... then... with the computer off... follow instructions for installing the card... connect the antenna... and then turn on. wiat for the computer to boot... it should automatically find the card... now... on the back of the cable modem... disconnect the wire that was going to the computer... and put it in the connection on the router that says "internet", now... disconnect the cable modem... wait 30 seconds... then plug it back in... wait 1 min. for everything to come up... now... connect the power to the router... and wait 1 min... go to the linksys icon in the taskbar... and double click on it... survey the site... when you find the wireless networks that are avil... choose the one that's got the strongest signal... and click connect. now... open the internet broser... and go to tools... internet options... then connections, down at the bottom... you'll see lan... click on it... you should see a box that says automatically detect settings... make sure this is checked...then click apply... then on o.k... and exit the internet.... then go back in... you should have internet...
Apr 03, 2010 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
My Latitude D610 Dell laptop is not connecting to the internet via my ZyXel broadcom router. In fact, the laptop doesn't even recognize the router or show the router as an option when I click on "Available...
1. Connect your router via LAN.
2. On your internet type in 192.168.1.1
3. Type 1234 on the password screen.
4. Go on the Wireless LAN tab
5. Un-check the option for Hide SSID
Dec 22, 2009 | Dell Latitude D610 Laptop Computer -...
My fiance is the the military! I sent him my old Dell latitude CP ... I forgot that it doesn't have a phone plug to connect to the Dial up on base. Is there a way to connect to the internet I don't...
I bought my sister a Dell laptop that didn't have a dial up modem in it, never saw one that didn't have one.
Dell sells a dial up modem that goes into the usb port for about $35, which I sent to her and it works. Basically it is just an external dial up modem.
Give it a try, just call the dell help phone number.
Nov 28, 2009 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Latitude C600, Ethernet adaptor NOT FOUND
Visit the Dell Web Site.. Use the Service tag on On under side of laptop.. and All Drivers are on the Dell Support Web Site!
Oct 09, 2009 | Dell Latitude C600 Notebook
Link with pc
hi,
If u want to connect through LAN Cable simply use on cross cable and then u will have to give the IP address to both computers.
Make sure that workgropup is same.
May 28, 2009 | Dell Latitude C600 Pentium III 750MHz,...
My Dell C600 won't recognize the 2 new 256 mb sticks of RAM
i think you need a same brand of 256 for it to work? and when you buy something for your computer make sure that the one you both is the same brand or code with your 128 for example you have 128 ddr2 sdram so you can only upgrade it with 256 ddr sdran or 512mb,1gb,2gb ddr sdram.
May 01, 2009 | Dell Latitude C600 Notebook
Dell latitude c600, battery not charging even charging sign is shown in windows (battery is ok and checked by another dell laptop) whats problem?
hi im josh in cebu phils.may i help you. friend try to check the small wire white near the batt.or check the connections if it is not shorted or disconnected. or try to replace new batt. good luck
Feb 22, 2009 | Dell C600 (002UH) Motherboard
Connecting to internect
Hi Linda........
1. You can disconnect the Rj45 cable from the PC & connect
it directly to your notebook's Rj45 port. You should have access to the internet if a minute or two.
2. if you want access to both, Pc & notebook you'll need a wireless router. Like the link below. Click it.
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01
You can find these types of wireless routers at places like Wallmart & Best Buy. They come in even smaller packages.
With the software that is included you'll be connected to the internet in no time. Linksys also provides security so someone near to your home can not tap your internet service & get a free ride. Linksys provides setup assistance from day one.
Hope this helps you Linda!
please vote...
Feb 25, 2008 | Dell Latitude C600 Notebook
Dell Latitude D610 Notebook Logo
196 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
