Or your exhaust is plugged.
If you have fuel , spark and compression , it must go
if you do not have as much compression as you should have then the problem will be crankshaft seal not sealing( if they are not good ,then when the piston goes up there is no low pressure in the sump to suck in the mixture as the seals leak air in so at this point I would suggest replacing the seals on the crank shaft
