Maytag MSD2756G Side by Side Refrigerator Logo
Posted on Jul 22, 2009
Things are not freezing
Our freezer is cold but not enough to freeze things and our frig side is not cold enough at all. Our Amana is 15 years old. Time for a new one? Thanks!
Anonymous
Level 1:
Champion:
  • Contributor 435 Answers
  • Posted on Jul 22, 2009
Anonymous
Contributor
Level 1:
Champion:
Answers
435
Questions
0
Helped
138329
Points
44
The gas is near finish in the system,or check out if the door is close firmly,no leaks
I have an Amana side by side frig and the freezer is not keeping ice cream cold. The refrigerator side seems fine. The freezer side is set to 7 but it no longer clicks like it used to when you turn the...
If you do not have guages (freon) and have a licens to proforme this type of work you will need to have someone qualified in this area to varify.You can call sears home repair @ 800 469-4663
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
Freezer isn't freezing all of a sudden but frig. side is still cold
There is a cheap repair manual for this model listed on eBay. The item number is 200262539606.
Premmy
Amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
1helpful
Amana frig
1.Dirty condenser coils where heat is transfered to the room air. 2.Frost build-up on back wall of freezer section which would indicate a defrost system problem.
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Bottom freezer not staying cold
One of two things. When you open the freezer drawer, do you hear a fan running? If not, that's the problem. The Evaporator fan. Its' job is to circulate cold air throughout the entire cabinet. Without it, things get toasty. If not the Evap Fan, it'll be the sealed system... meaning that it's developed a leak and freon is escaping (not harmful for you or your Family). If it's just under 5 years old, this will be a warranty repair. Over 5? Bad news... it'll cost ALOT to have it repaired.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
