The system cannot find the file specified
When i turn my laptop on it goes straight to the message ''the system cannot find the file specified''
  • MTreeBandit May 11, 2010
    Does it give the name of the file it cannot find? Chances are you have a broken Windows or just a system file has become corrupted.
  • 244 Answers
You don't mention what Operating System you are using.
If its Vista, just insert the Restore CD, and afetr answering a couple of questions, the CD will ask you if you want to repair the boot file.
Select yes, and Windows Vista will do the rest for you.
If you are using Windows XP,
It appears that you have a corrupted or missing file, probably due to a bad shutdown, or an infection of some sort.
You should use your RESTORE CD, and boot from it.
Select the Repair option, and perform a CHKDSK /p command.
This command will not only check for your disk integrity but also check and replace basic files needed for your computer to start up properly.
Please don't forget to rate this answer if it helps
Posted on Jul 22, 2009
I get the error message system cannot find specified registry key or value
Try a system restore and bring computer back in time before the error occured.
Mar 26, 2012 | Computers & Internet
Windows cannot access specified device, path, or file... app perm
sounds to be a bug in the system
ensure the program is working, goto system restore and turn it off
turn back on again, this will remove all the old ones, they could have the bug in them,
create a restore point now, then download "combofix.exe"
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
run this
it gives a report when finished, the top section shows deletions, this is the stuff it found
Nov 12, 2009 | Dell OptiPlex GX260 PC Desktop
Fsck error HELP! HELP ! HELP!
fsck is a file system error check command. Try the root password of nothing, (just the enter key), when ask for the password. Then use the fsck command to repair the file system before rebooting.
fsck - check and repair a Linux file system Try fsck with no options.
SYNOPSIS fsck [ -sACVRTNP ] [ -t fstype ] [filesys ... ] [--] [ fs-specific-options ]
DESCRIPTION fsck is used to check and optionally repair one or more Linux file systems. filesys can be a device name (e.g. /dev/hdc1, /dev/sdb2), a mount point (e.g. /, /usr, /home), or an ext2 label or UUID specifier (e.g. UUID=8868abf6-88c5-4a83-98b8-bfc24057f7bd or LABEL=root). Normally, the fsck program will try to run filesystems on different physical disk drives in parallel to reduce total amount time to check all of the filesystems.
If no filesystems are specified on the command line, and the -A option is not specified, fsck will default to checking filesystems in /etc/fstab serial. This is equivalent to the -As options.
May 27, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
System Failure
your system might hv infected with virus., boot from the antivirus bootable cd, clean the viruses., then next time., it will boot to normal., install good antivirus with latest virus definitions., and put for full system scan., then its ok
Mar 26, 2009 | Norton SystemWorks 2005 Premier Retail Box...
Error message on my Dell laptop Inspiron 5100
A task has been left behind by the Paretologic Program in the task manager's files that is responsible for this annoying error..to fix ..go to START ..ACCESSORIES .. SYSTEM TOOLS ..click on ..SCHEDULE TASKS and delete any tasks that concern Paretologic
Feb 27, 2009 | Dell Inspiron 5100 Notebook
I installed Dimage x onto my new laptop with windows vista. First, I received a message that it was not compatible...but then there was something to click that made it compatible. After that I downloaded...
I can't help with the techy side I am afraid but we have the same camera and also have a vista laptop. We have not had a problem but I don't think we have ever tried plugging the camera into the laptop as I just put the sd card straight into the laptops card reader and save straight from it. Easy peasy.
Glad I spotted this though. Good luck
Dec 29, 2008 | Konica Minolta DiMAGE X Digital Camera
Nothing is opening on my laptop
hi, you may be using windows XP with NTFS file system.
some body/virus has redused the file permissions in your system. Scan the system with an updated virus scanner.
thanks
Aug 16, 2008 | Toshiba Satellite A135-S2386 Notebook
My Toshiba Laptop
click Start>>Run>> (type)Msconfig>>Click ok
System configuration utility window will open up
U will see few tabs at the top like General,Startup
Click on startup tab
At the bottom click disable all>>Close>>It will ask for restart
Restart the computer
when the computer restarts you will get the message
You have used the system configuration utility
Check the box at the bottom Do not Show this Message Again and click ok
Now you wont see the icons that use to load up on the right bottom of your system,however they have not been deleted just hidden,if you want to access any of those programmes that use to appear before
Click start>>All Programmes>>and clik the application you need to open.
May 25, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
