How can I connect two six volt stereo speakers to my car 12 volt supply. When I connect them in series across the 12v battery, only one speaker will work !
  • 7 more comments
  • ricketts_ton Jul 22, 2009
    The two stereo speakers have a builtin amplifier that normally operates from 6volts. I wish to connect the speakers to a 12volt supply. This connection is only for the amplifiers not for the speaker impedance !
    My problem concerns the connection of the internal amplifier within each 6v speaker {not the speaker itself} the internal amplifier {s} within each speaker is 6 volts. I have a 12v supply from my car battery. When I connect the internal amplifiers in series, only one speaker will operate. My question is how can I connect the two speaker {amplifiers} to operate on the 12volt circuit.
    The two speakers both have internal 6volt amplifiers. I am referring to the connection of these amplifiers within each speaker. I would like to know how to connect the 12volt circuit from my car battery, to enable the pair of 6volt amplifiers operate. The impedance of each speaker is entirely seperate from the amplifier circuit .
    when I click "reply" and then "adda comment" then click "submit" the screen reverts back to solution number 2 ! Are you receiving my replies please .
    I have two amplified speakers. Each speaker has a built in 6volt amplifier. I wish to connect the internal 6volt amplifiers of this pair of stereo speakers to a 12 volt supply. Can you supply a circuit diagram to enable the speakers to operate. The impedance of the actual speakers is not part of the circuit, I am only concerned with the supply to the amplifiers.
    This is the best answer yet, but it still does not give me a proper answer! The link given for a dc to dc convertor is invalid ! If I connect each 6v amplifier in parrellel to the 12v battery this would give each amplifier the correct polarity, but of course too much voltage.
    Could someone recommend a resistor or transistor that I could wire in series with each amplifier to reduce the voltage going to each amp.
    my problem is related to the amplifiers only built inside each speaker. The actual speaker is a completely seperate circuit. The speakers are designed to be connected to a portable CD player, and have 4 "C' CELL internal batteries. The batteries go flat very quickly, this is why I would like to use the facility to connect the speakers to an outside power supply. The speaker amplifier requires 6v. There are two speakers. I have a 12v supply from my car battery. If I connect the amplifiers in series ONE of them only will work OK. I think that if I connect them in parellel to the 12v battery this will give each amp the correct + and - but 12v instead of 6v. What I need to know is.....what {say} resistor can I put in series with each amplifier to reduce the voltage from 12v to 6v ?
  • ricketts_ton Jul 23, 2009
    Hi Heavymetal,
    Thanks for your reply which fits my request the best so far. Can you tell me just what to ask for at the electronics store. atahe transducer probably has a "value" ?
    Now you know more about my problem, can you please give me your $4 solution.
  • 1,555 Answers
Here is the item which you are required to purchase. Why you wan't to jumble your car with manual wire lying and resistence. You will have to get a soldering iron and a bread board to make your convertor yourself and its also not that easy that you will be able to make. You will require the circuit diagram of that converter first.
Below I've given you the item which you require to puchase for playing your spakers and more over alongwith just playing your speakers you can use it also as your phone charger playing your pocket CD player or whatever you wan't. Thats not too costly also.
12 Volts (10V-30V) in 1.5V, 3V, 4.5V, 6V, 7.5V, or 9V out Low Current DC/DC Converters 12 V to 1.5, 3, 4.5, 6, 7.5, or 9 V These inexpensive 24 watt DC-DC converters are useful for automotive applications
Posted on Jul 23, 2009
  • 721 Answers
Ok,I've read you posts. I'm not a complete audio expert but I have alot of electronics experience in the auto field in genral. So I think I understand what you're trying to accomplish. You want to connect them parralel so each would get 12v but you need to step it down to 6v. There's a few ways to do this, one research the resistors used on older dodge cars,known as the ballast resistor for the ignition coil. Some do step 12v to 6v but I forget which year or model. Any chrysler product will do,as long as it was designed to drop to 6v. The other way is to go to radio shack or equivelent & get a transducer or variable resistor to do the same thing. Hope this helps.
Posted on Jul 22, 2009
  • Pete MacSparran
    Pete MacSparran Jul 23, 2009
    No it would be a generic variable resistor. It should be marked for the 6v setting you need. Just turn the dial on it,should be a simple 2 wire connection,just splice it in for 2 speakers.
  • 11,896 Answers
If you are hooking two 6 volts up to one 12 volt, the power is splitted into the 2 speakers 6 volts in each. Otherwise you can replace the power supply as long as it has the same ohm rating as your speakers.
  • 336 Answers
You will need a step down down DC-DC (12V to 6V) converter for that. Unfortunately, it's very hard to find this in the market but if you have a good electronics foundation, you can build one. Here's one brand of the converter models. I hope it helps.
http://www.national.com/mpf/LM/LM338.htmlhttp://www.national.com/mpf/LM/LM338.html
Regards,
Jeep Brainy
  • jeep brainy Jul 22, 2009
    Apologies, looks like I've pasted the link twice, here is the correct one.
    http://www.national.com/mpf/LM/LM338.htm...
    Note that this regulator will only give you an output of 5amperes (6V) so check the current or power rating of your amplifiers. You may need one for each of the two amplifiers.
    Regarding a a resistor in series with your amplifier to reduce the voltage, I would not really recommend that since you don't know the supply line resistance of your amplifier. Also, you will be needing a very high wattage resistor to do that, take not that you battery is giving off 12 amperes so your resistor will really get hot and will die/blow in the long run.
    Regards,
    Jeep Brainy
    Top Expert:
  • Audio Player... Master
  • 78,267 Answers
Speakers are never connected in series they are always connected in parallel, also speakers are rated in Ohms of impedance not volts
  • yadayada
    yadayada Jul 22, 2009
    SURE WOULD HAVE BEEN NICE IF YOU PROVIDED ALL THE INFO ABOUT THE SPEAKERS BEFORE I WASTED MY TIME AND YOURS ON THIS $4 PROBLEM.
    Genius:
  • 1,689 Answers
Hi Ricketts,
I strongly suggest you put a converter in between the unit and the power supply. this will even out the power and the ohms coming into the speakers. the reason why you only have one speaker working is that the speaker cannot sustain too much voltage into it.
http://www.powerstream.com/dc6-12.htm
hope this helps.
Regards,
voodoo
How to wire two extra 12v batterys to a 24v mobility scooter to increase the amps
Connect the two extra 12 volt batteries in series to get 24 volts. Then connect this new 24 volt supply in parallel to existing 24 volt battery supply.
Jan 30, 2017 | The Health & Beauty
Trying to hook up aftermarket stereo with no factory harness. How can I go about wiring my new stereo wires or my replacement harness (with module) to my car's already existing loose stereo wiring??
Hi Daniel
You need to test & label all the loose wires.
Use a multimeter in Ohms mode to place a tickle of electricity to each speaker wire. you should hear each speaker crackle. (Multimeters only use a 9v battery internally)
Label each pair of wires for speakers.
Their color coding may help. Keep the negative & positive wires to the speakers correct so that the speakers all travel in a forward motion together or you will have distortion from one speaker that is out of phase with the others.
You will also have a permanent +12v line and a Ignition Key +12 volt line.
One keeps the station memory etc when the ignition key is off.
Cheers
Car Stereo Wiring Explained In Detail
Car Stereo Wiring Basics
How to Install Replacement Car Stereo
Mar 01, 2016 | Cars & Trucks
A voltage drop from 12 to 6 volt or find the cuase of it
I'd start by checking ground connections. How are you checking voltage at the relay? Across the coil, or coil to ground? Coil to ground is important to check.
Oct 23, 2015 | 2001 Dodge Grand Caravan
I have an old car stereo I want to wire so I can plug it into a 110 outlet. Is this possible if so how?
not possible without adding a battery charger unit to convert to 12 volt
Aug 09, 2015 | Cars & Trucks
I HAVE TWO YELLOW WIRED POWER AN WHAT..95 CAMARO REWIRING RADIO
Below is a listing of the radio wires and what they control.
1995 Chevrolet Camaro car radio wiring schematic
Car Radio Battery Constant 12 volt Wire: Orange
Car Radio Accessory Switched 12 volt Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6.5" speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire: Tan
Left Front Speaker Negative Wire: Gray
Right Front Speaker Positive Wire: Light Green
Right Front Speaker Negative Wire: Dark Green
Car Audio Rear Speakers Size: 6.5" speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire: Yellow
Left Rear Speaker Negative Wire: Brown
Right Rear Speaker Positive Wire: Dark Blue
Right Rear Speaker Negative Wire: Light Blue
Jul 08, 2014 | 1995 Chevrolet Camaro
91 geo prizm stereo wiring diagram
Check with a Volt meter for 12 v constant and 12v when key is turn it on and a ground . The rest of them is speaker wires, to check the speaker wires all u need is s AAA or AA battery. Put the wire on each end of the battery + and - with two wires you will hear speaker static then you know which speaker..
Sep 17, 2012 | 1991 Geo Prizm
Problems with bose companion II 12 volt adapter
I found that the 12v power pack from an external hard drive works fine. I think you need the 5.5 x 2.5 mm plug.
Jun 12, 2012 | Bose Companion 2 Series II Multimedia...
Wiring diagram for a Sony XR-C210 car stero
SONY XR-C210, XR-C214
1-GND
10-+12 VOLT BATTERY WIRE
16-Speaker RF-
5-Speaker RR+
11-+12 VOLT IGNITION WIRE
17-Speaker LF+
6-Speaker RR-
12-Power Antenna Turn On
18-Speaker LF-
8-Speaker LR+
13-TEL MUTE
9-Speaker LR-
15-Speaker RF+
Sep 13, 2009 | Sony Car Audio & Video
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
152 people viewed this question
 Grubhead
Grubhead
