Question about Hotpoint NVL333EY Electric Dryer
Model NVLR333EVOWW Not heating up
NVLR333EVOWW- Hotpoint dryer stopped putting out heat. There is nothing blocking the venting as it blows cool air freely. I don't see the heating element lighting up unless I tip dryer. Then it buzzes and like sparks. Its as if there is a bare wire or something..?
  • hmackjr Sep 18, 2009
    Hotpoint dyer NVLR333EVOWW does nothing. Just stop working.
  • 534 Answers
Your element has burnt in half where the sparks are coming from is the end of the element touching the metal. You need the model and serial number go to the nearest appliance parts supplier and get a new element they aren't that hard to replace. Always make sure you disconnect the power source before doing any repairs to the dryer. Good Luck
Dave
Posted on Jul 22, 2009
  • bow_hunte930 Oct 24, 2010
    where is the heating element
Sound shuts off every hour for about 3 secounds
Sounds like an over heating issue. Check to see that there is nothing blocking the vents on the unit, nothing on top of the unit when running, especially nothing on top that generates any type of heat.
Oct 09, 2015 | Audio Players & Recorders
Dryer is only 5 yrs old. Started to blow cool air. Not heating. Vent was blocked from outside. Cleared vent, flab is open, but dryer still not blowing hot air. Is there a reset on this machine? Why...
There is a device in the circuitry for the heating element which shuts off power to the heating element when the dryer gets above a certain temperature which is ealsily reached with a clooged vent hose. This device, a thermal limit switch or thermal fuse, cannot be reset, it has to be replaced.
If you want to do this yourself, let me know -- if not, you will need to arrange for someone to repair the dryer. The device costs about $20 -- a service tech will probably charge up to $150 for the repair.
Charlie
Jul 26, 2011 | Kenmore 600 7965 Dryer
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
My hotpoint ctd40 has stopped heating again, the
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Dec 22, 2009 | Washing Machines
My electric dryer is not blowing heat, just cool air. What is wrong with my dryer.
Check the following to address this issue.
1. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
2. Thermal fuse
Sep 23, 2009 | Amana Dryers
Amana NEW7200TW (1 year old) runs, but stopped heating.
Jul 30, 2009 | Amana NED7200TW Electric Dryer
My dryer is not producing heat. Just cool air!
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
3. Thermal fuse
Jul 17, 2009 | Dryers
Hotpoint aquarius ctd00 does not blow hot air
If gas, check the following.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
If electric, check the following.
2. Heating element
3. Thermal fuse
Jul 09, 2009 | Hotpoint Dryers
Dryer is working but won't heat. Its just blows cold air. Help please the model is a hotpoint dryer nvlr333evoww.
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, whcih requires
replacemant.
Jul 05, 2009 | Dryers
IT RUNS BUT DOES NOT PUT OUT HEAT
Check the following to combat this issue.
Heating element
Thermal fuse
Jun 19, 2009 | Hotpoint NVL333EY Electric Dryer
Hotpoint NVL333EY Electric Dryer Logo
930 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
