Question about GE GSS22JFMWW Side by Side Refrigerator
Top portion of rrefrigerator on refrig side is hot
In the morning the top of the refrigerator is hot and it resets after the door is opened and immediately begins to cool. Is it hot to the touch and the items in the top half become warm. The computer board was repalced and ther same thing happened again.
  • 248 Answers
Check to see if refrigerator door is even with freezer door at top, or is it lower. If lower, the light switch may not be contacted fully. Remove toe plate , bottom front on fridge. Under refrigerator door bottom hinge is a threaded rod. Adjust this to raise door to make level.
Posted on Nov 21, 2007
Refrig door does not seal
First off, make sure nothing is stopping the door from closing completely. If the door is closing properly, then using a hair dryer, heat the gasket until soft and pliable. You can carefully stretch it towards the cabinet. There is a magnet in the gasket all the way around on the mating portion. While the gasket is soft, the magnet will pull the gasket until contact is made with the cabinet. Once a good seal has been accomplished, allow to door to remain closed for 30 minutes. The seal will cool down, and the new shape will be maintained. After that, close the door on a dollar bill. Gently tug the portion of the bill on the outside of the door from one corner to the other. There should be some resistance to your pulling. If the bill feels loose, apply more heat to the gasket in that area to improve the seal. DO NOT HOLD THE HAIR DRYER IN ONE PLACE TOO LONG AS IT WILL DAMAGE THE GASKET, AS WELL AS THE PLASTIC LINER.
May 08, 2014 | Refrigerators
Kenmore Refrig Model 596.50699000, not getting cold as should. Frost forming on top row of coils only?????
Clean the condenser. Probably below refrig. Reset all settings to mid point and check to see if you have a restricted drain tube.
Jun 17, 2012 | Kenmore Side by Side Refrigerator
I made chicken broth last night and didn't let it cool properly before putting the broth in the refrigerator. About 7 hours later when I woke up this morning, the refrigerator was hot and most of the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp. The problem could be the electronic control if you have one or the mechanical linkages.
Nov 03, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
I have a GSS25KGMD fridge. I opened the Fridge compartment top part was very warm and the bottom was cooler. Upon investigating more I noticed that the fridge bulb was very hot. So I pushed the fridge...
Your refrig light switch does control the freezer fan and the refrig light bulb . Replace the refrig light switch .
Open the refrig door , freezer fan goes off and the refrig light comes on .
Nov 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
It was working fine yesterday. When I got home I
Try unplugging refrig for a few min , then plugging back in . This will reset the adaptive timer and at least get the refrig working . The adaptive timer , is located in the control panel . Pt # 4388932 . To replace this board , remove the knobs and pro the top of the panel outwards . Remove the 4 screws holding the panel ( 2 are on the inside by the light bulb ) . You should now have access to the board .
Sep 30, 2009 | Whirlpool ED5VHGXM Side by Side...
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS22JFMWW Side by Side Refrigerator Logo
245 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
