Question about Refrigerators
I have a kenmore refrigerator Not cold enough does it need
I have a sears kenmore refrigerator 106.59589990... I had a horrible repair guy come here and fix it.. Well I got a work over. Charged me $145 for a defrost timer (yeah part only NO LABOR) He had it on the receipt he gave me from Sid harveys)
Well last I know he said he took off the coil to defrost it. I went I bought the correct timer from Sears $30.00 and installed it myself. Question is fridge seems to be working but not getting cold enough could it have something to do with him taking off the coil and it needs to be recharged?? Please Help and dont say get him over again.. Im contacting AG about his fraud!
  • lismarmis Jul 22, 2009
    Thanks dave thats what I thought.. The fridge is cooling seems to work after a bought new defrost timer, but not quite getting cold enough. 32 degrees in freezer and 42 degrees in fridge compartment.
    Also bottom coil inside freezer is starting to get frost on it again. The defrost heater does work.
    PS>I know when my boss gets back I am letting him know not to use this kid or the company he works for. I know all are not crroks but I have had 2 bad repair guys so far! One charged me $150 for a cob job.
    Plus I am going to file a complaint with AG. I dont mind paying the cost for the part but not $145!! when it was only $26.00!!
  • lismarmis Jul 24, 2009
    Hi Dave, well I took off the inside freezer panel. Frost was only 1/2 way up. Used a hair dryer on it. Plugged it back in and know we'll see. I do know that he used the wrong defrost timer on it. Should I just leave the dials mid range for know and turn them up in 24 hours? Maybe that is my problem. Maybe I jacked them too quickly!
  • 534 Answers
Sorry to say this but if he did take the coil off to defrost it he had to have removed the freon.
I would call another service company and have the unit recharged. Not all repair techs are like that they give all of us bad names. Good Luck
Dave
Posted on Jul 22, 2009
My kenmore coldspot # 10659537990 gets to cold freezes everything have to turn off to get it to stop
Sounds like you need a thermostat. I suggest calling a reputable repair service. Seeing it is a Kenmore I would call Sears.
Hope this helps you...Jim...Please leave a comment
Feb 13, 2011 | Kenmore Refrigerators
Why would the refrigerator of my Kenmore model 253.64802400 stop being cold?
Model# 253.65812508 Serial#Ba74017239 Had a repair person from sears to check out the refrigerator he said the compressor is not working. Can you tell me if the warranty cover this item
Nov 11, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore fridge not get cold enough and coils icing again
check all heaters on frezer side and check coil under unit to make sure clean ajust timer at the top of icebox side behind plastic plate where light bulb is it shold be onthe right side top turn until unit turns off then turn one half this is the timer for defrosting cycle.
Jul 23, 2009 | Kenmore Refrigerators
Ice machine wont dump ice on sears kenmore side by
Ice forms are 32 degrees but ice maker don't dump till 25 degrees. Get that guy back out there. Obviously you have a bad defrost heater.
Jul 17, 2009 | Refrigerators
Fridge compartment is freezing
It is the part # 2315515. It is a motororized contraption that opens and closes the baffle to let the freezer air into the refrigerator. It is one part. Mine shut closed. I removed the whole thing in hopes I can do without it. It will be a trickey proposition getting the freezer temp adjusted just right enough to keep the fridge just right enough. The repair man said they are seeing alot of these right about now. They don't make em like they used to.
Jun 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a side by side and the fridge part is not cooling enough.
Sounds like a defrost problem. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there, Thanks, Sea Breeze
Jun 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not cold enough, but running it seems
Sounds like coolant is low in the system. Most fridges use a sealed system with refridgerant.
You may be able to have a sears guy or some other applicance house call repairman come and recharge it.
Also.. check that there is enough clearance around the fridge and that dust isn't clogging up the heat transfer pipes (that grid on the back.. or below the fridge) These guys need a lot of airflow to remove heat.
Oct 31, 2008 | Kenmore Refrigerators
Installed replacement Icemaker but will not dump new ice...
Either your freezer is not cold enough or you got a defective ice maker. It needs to be 15 degrees or colder to make ice. The water may be frooze but not cold enough to close the internal thermostat inside the ice maker. If your freezer is colder that 15 degrees, take the ice maker back to Sears, you got a lemon. Good luck!, Mack
Jan 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
