Question about Dell A940 All-In-One InkJet Printer
I turn the printer on to print something and it shuts off
I turn the printer on to print something and it will go to print and then shut itself off it will never do the print job what do I do now?
  • 41 Answers
Well i think that u need to reset your printer,
but first of all u need to tell me that what is the make of the printer and the configuration of the computer or what i can suggest that go to google and try to search how to reset printer and u will get the solution or else u can contact me on fixya
Posted on Jul 22, 2009
Laser printer shuts down immediately
A laser printer that shuts itself down immediately after turning it on indicates either a loose power cable which can be fixed by pushing the power cable in properly or something internal to the printer is causing it to shut down.
If it is shutting down due to something internal, one possability is it has the wrong power going into it. a 110 volt power supply going into a 220 volt printer or the other way round change the supply or find a converter for it. Another possibility is some other component in the machine is failing such as the power regulator board or format board. If it is something internal like this. Replace the printer is really your only option unless it is still under warrantee as replacing parts in most machines nowdays is more expensive than buying a new printer.
Aug 19, 2014 | Brother HL Office Equipment & Supplies
Cannon MP600 printer shut itself down during printing operation . Pressing ON/OFF button will not turn it. I checked connections and power source. Still, no reaction.
Re: "Cannon MP600 printer shut itself down during printing operation ."
If a Canon inkjet printer is turning itself off, then problem is either control board or power unit. When this happens printer is often considered beyond repair, and in any case it must be tested by a technician to find out the problem.Repair involves testing volts out from power unit and testing components on main board.
Considering that the MP600 is quite an expensive inkjet, I suggest contacting Canon support and asking a quote on repair.
Here Canon support pages:
Canon U.S.A. : Contact Us
Canon U.S.A. : Support
Canon UK - Support
Canon South Africa - Support
Aug 30, 2010 | Canon Office Equipment & Supplies
My HP Laserjet 4 will power up and print beautifully for about 5 minutes, then it shuts down - all lights go out, no fans working - nothing - dead! I have to turn the power switch off and wait several...
Have you powered-off the printer, unplugged the AC power, and used a can of compressed-air to give the printer a "blow-job" ?
A layer of dust will act as a layer of insulation, causing the printer to overheat, instead of "radiating" the heat.
Sep 17, 2009 | HP LaserJet 4 plus Printer
Paper jam after first page prints.
Most likely something in the printer or software is set to an improper paper size. It's saying jam because it prints the first page and registers an incorret size.
Check BOTH the printer itself and the program you're printing from.
Feb 26, 2009 | Dell 1600n All-In-One Laser Printer
New printer does not work. get message printer busy with something else
Hey Donald hows it going, sounds like the printer is frozen up or theres a file still waiting to print thats jammed so what we are going to do is the following
press cancel on the printer itself and see if the printer will clear the printer if not,
disconnect the printer from the computer itself turn the printer off and unplug it from the wall wait a few minutes and plug it back into the wall and dont plug it into the computer just yet make sure that its fuctioning by printing out a test page from the printer itself if this works then we know its not the printer but the computer. this ushally means there is a full que or something that hasnt been printed or paused which happens here and there best thing for that would just be simply shutting down your computer waiting a minute and turn it back on and then attach the printer while its on. and see if you get the same results as you did before only this time do a test page through wordpad or notepad just put a line or two of text for testing purposes.
See what happens did we get it?
if not please let me know and I will or others will try to help the best we can in getting this issue sorted out for you.
Sep 26, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Printer isn't functioning
While using my printer, it appeared to shut itself down. The power button did not work. I called Canon and the service rep instructed me to disconnect the power cord from both ends (from the printer and the outlet (for 5 to 10 minutes). When I reconnected the printer, the printer worked fine. The rep stated the machine will do this rather than become damaged from a power surge. Hope this helps.
Sep 15, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Lexmark x6170 random shut off while printing
I think the power saving mode is on your printer ?try setting to off mode or 2 hrs mode...
Mar 13, 2008 | Lexmark X6170 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
48 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
