Question about JVC AV-32D305 32" TV
Why does my on timer light stay on (not blink) but yet I can't get picture or sound
  • 3,037 Answers
Sounds like the power supply needs to be replaced with the symptoms given. Any person with electrical experience will be able to put a new one in. These tvs are starting to be outdated, so if you are looking for an excuse to upgrade to an LCD tv, now would be the time. Otherwise, let me know how this turns out.
Benjamin
Posted on Jul 22, 2009
5 Suggested Answers
  • 108 Answers
SOURCE: blinking lights on the power button
replace the lamp.
Posted on Jan 08, 2009
  • 285 Answers
SOURCE: standby blinking no picture or sound
Ok. I think you'll need an IC or a PSU.
Posted on May 24, 2009
SOURCE: tv picture is going out and standby/timer light blinks
Hi Kevin!
The issue may be related to the projection lamp in the TV and replacement may be required. However, before replacing the projection lamp in the TV, you may perform the troubleshooting steps mentioned below.
Please disconnect all the cables from the TV including the power cable then reconnect them after two minutes. Please make sure that the the power cable from the TV is directly connected to a functional wall outlet. Next, you may try connecting any other video source such as cable box, DVD player, Blu-Ray player, Playstation, etc. If the issue persists then try resetting the TV to the original factory settings.
Please follow the steps mentioned below to reset the TV to the original factory settings:
(i) Turn the TV ON.
(ii) Press and hold the Reset button on the Remote Control supplied with the TV, then press the Power button on the front panel of the TV.
(iii) Next, release the Power button. The TV will turn itself off, then back ON.
(iv) Release the Reset button.
If the issue persists then you may replace the projection lamp in the TV.
Posted on Jul 12, 2009
  • 8457 Answers
SOURCE: Blinking timer light, No picture or sound.
Ur high voltage is dead,the FBT,the flyback transformer,the big black block of plastic with a red wire with a cap hook to the CRT(tv tube).That is dead.
Posted on Sep 27, 2009
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Timer light blinks , no picture , no sound
Hi next time please post a model # so we can give a better answer.
if this is a sony LCD projector sounds like a bad lamp, easy to change costs about $200 from sony
gd lk
Eric
Aug 27, 2009 | Televison & Video
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Standby Blinks 5 times. Picture goes off but sound stays on. Only hookup is Digital Cable - help!
Plug the electricity to a surge protector. I fixed my that way. Try it and let us know.
Jun 28, 2008 | Sony KP-53HS10 TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Blinking green light, no picture or sound
Hi, bought television only 2 months ago now blinking opc light and power lights with no picture or sound. Whats up with that?
Sep 13, 2007 | Mitsubishi WD-62525 62" Rear Projection...
JVC AV-32D305 32" TV Logo
22 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
