Question about Roland Vs-2000CD Digital Studio Workstation System
VS-880 - NEED MOUNTING CADDY FOR INTERNAL HARD DRIVE
Hi, I have a Roland VS 880 working with an external drive through SCSI. I purchased this preowned without the mounting caddy required to install the internal hard drive. How can I get this mounting caddy (besides from Roland, they won't help....). Thanks!.
3 Suggested Answers
SOURCE: roland vs 880 help -
  • Roland vs 880 or BR-8 ; Could this machine play more than eight tracks at the same time?...how?
Posted on Apr 08, 2008
skotkolr
  • 558 Answers
SOURCE: luckeywalker@yahoo.com My Roland VS 880
that would depend on where you are located in the USA doesn't fix ya have people who do repair work in another section.?
Posted on May 28, 2008
I have a Roland vs 840 ex it has had a c.f. drive installed the machine seems to work perfect except when I set up and get ready to record and depress play or rec it says no disk. It has a 4gb c.f. card.I...
Try to initialise (format) it in your computer. Use an external card reader. I think you should use FAT 16 or FAT 32. But once the Roland sees the card, do an initialise there.
It could be the Roland can;t work with memory cards above 2 Gbyte, for that try to make a 1 Gbyte partition in your computer and again try if it works.
Feb 10, 2015 | Roland Vs-840 Digital Workstation...
Cf-29 no operating system
You will require the internal Panasonic Toughbook CF29 optical drive (DVD). The cost of such a drive (used) in should be $50 or less.
You will also require a Windows 7 DVD.
You may be able to download an ISO file and burn your own.
Try this Microsoft Website:
https://www.microsoft.com/en-ca/software-download/windows7
You must use the 32-bit version, NOT the 64-bit version.
Please remember to set the DVD as the first boot device in the BIOS of the CF29.
That is it. Good Luck and Best Regards from:
Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Jan 27, 2014 | Panasonic Toughbook 34 PC Notebook
Problem getting VS-2480 to connect to internal drive. also to external drive sometimes it works sometimes it won`t Need service manual for mounting new harddrive internally SATA 160 GB Experienced...
Hi Karl,
First of all, thank you for purchasing the copy of Roland VS-2480 Service Manual.
Please email me at mjsvillanueva23@yahoo.com, I will send you the copy.
May you and your family have "Prosperous New Year 2012"!
Again, thank you so much!
Mjsazon
Dec 29, 2011 | Roland Vs2400CD Digital Workstation W/CD...
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
Installing Hard drive in external caddy
No, you don't remove the board. The drive won't work without it. Just install the drive in the case and connect everything up. The computer will find it and assign a drive letter to it.
Feb 03, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Trying to locate a HDD caddy/Connector
In normal circumstances it would be a USB 2.0 but I don't know what you are connecting it to.
Jul 29, 2009 | Computers & Internet
Acer harddrive working also in other Acer notebooks?
You can physically install the drive in any laptop with the same type. They will either be SATA or IDE. However unless you have a nearly identical system which is unlikely after a few months of buying it the windows installation is not likely to work.
The better solution would be to stop in at your local computer store and purchase a 2.5" drive caddy and install the HDD into the caddy. That caddy will then work as an external HDD on any computer you purchase allowing you not only to access the files on it but also to backup any new data.
Chris
May 31, 2009 | Acer Aspire 5100 Notebook
Difference between HDD and SATA
Buying a new SATA hard drive is confusing if you don't understand the differences between the various drive types. Which hard drive should you buy?
SATA Hard Drives (Serial ATA) are the most popular drives being sold today. Alongside them in the store however you will also find boxes labeled Parallel ATA or SCSI. So what are the differences between these hard drives and which one should you purchase? Your decision is dictated by what your computer can accept. Check with your computer's manufacturer to see which drive style you can use. Most newer computers purchased within the last two years accept SATA connections. If your computer cannot accept one of the newer SATA hard drives you can purchase SATA adaptor cards that plug into an empty expansion slot on your computer's motherboard. You can purchase SCSI adaptors as well, so follow these tips to guide your decision.
SATA vs PATA: Serial ATA vs. Parallel ATA Drives SATA hard drives have many benefits over their older cousin, the Parallel ATA drive. Chief among these differences are:
  • SATA hard drives are faster and perform much better than traditional ATA drives and are better for high bandwidth applications such as video editing and multiplayer gaming.
  • SATA drives use a smaller, cheaper cable to connect to the computer's motherboard. These cables can also be up to three feet in length compared to eighteen inches with Parallel ATA cables.
  • SATA hard drives can be hot swappable, meaning that they can be disconnected and reconnected without powering down the computer. There are limits to this of course. You should never disconnect your boot drive while the computer is operating.
  • SATA cables are easier to plug in without damaging the delicate connecting pins on the drive.
  • SATA hard drives are significantly faster than external USB hard drives.
SCSI Hard Drives SCSI hard drives are the elders of the storage world. SCSI is one of the oldest specifications but it is also the fastest and thus has been widely used in network servers and other high speed, high bandwidth applications. Unfortunately this high speed storage has also meant much higher costs. SCSI drives were once standard in all Macintosh computers but have since been replaced by the cheaper SATA based hard drives.
  • SCSI drives are also hot swappable, similar to the SATA drives.
  • Some varieties of SCSI can be used with SATA
  • SCSI drives are often set up in a mirroring arrangment to allow for instant, continuous backups of the hard drives.
  • SCSI drives are still the most expensive drives on the consumer market.
Your basic rule of thumb should be to purchase a drive that is designed to work with your computer's motherboard. Try to avoid using SCSI adaptors or SATA adaptors unless absolutely necessary as the whole point of using a specific kind of hard drive is to get the most speed and storage for the money.
Thanks alot,
Sanjeev Kumar
Jan 22, 2009 | Tablets & eReaders
Luckeywalker@yahoo.com My Roland VS 880
May 27, 2008 | Roland Vs-2000CD Digital Studio...
Roland Vs-2000CD Digital Studio Workstation System Logo
528 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Joseph Mueller
Joseph Mueller
Jerry Greenberg
Jerry Greenberg
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
