My technika lcd 15id-107 has been tuned to my sky box in another room for a year now. When I switched on today it wont tune to the sky box anymore. spent hours trying to retune. Help
  • 11 Answers
SOURCE: Digital tuning
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
Posted on Nov 04, 2007
Emsy32
  • 3 Answers
SOURCE: Sky remote handset will not operate mute. volume etc.
Go to interactive
Select Number 5
Then select the remote option (5) You will then get a list of tv models with codes, follow the directions on screeen
Posted on Jan 06, 2008
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
SOURCE: tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Posted on May 19, 2008
SOURCE: technika tv lcd 19-907 tuning in to sky in bedroom.
Hi, with regards the tuning in of the required station I started from the beginning again and after the digital channels had been automatically tuned in it asked if you wanted to tune in the analogue channels . I clicked on the yes button and it tuned in a number of channels and when checking through the channels I found the sky channel required from downstairs which is linked by an aerial connection.
AS Gordon Ramsey would say :------ telly tuned in DONE
Posted on Dec 15, 2008
How do I tune my TV in the kitchen to my Sky box in another room.
Sky box stuck in Stand By on red light Sky Box Guides faq
Sky Troubleshooting faq
either you have it hooked up wrong or skybox doesnt allow 2 screen use,you may need another skybox
May 14, 2015 | Televison & Video
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
How do I get my Sky channel back on analogue after re-tuning freeview
Go in to analogue tuning. Tune just the analogue side of the TV.
Sep 05, 2014 | Televison & Video
User guide for a technika sc 500172
hi i have a technika tv but when i tune it in i dont know how to lock them in
Dec 28, 2010 | Televison & Video
Technika TV Tuning Problems
hi the same happened to mine. a22inch freeview dvd.wont pick up a signal when tuning in.Its had very little use ( 150hrs ish) as its in our caravan. we now plug in a separate freeview box via the scart.Tesco dont want to know as it was 3months out of warranty at the time of complaint.Anyway Im meeting Tesco in County court in july. It appears to be a common fault
May 13, 2010 | Televison & Video
How do I tune this TV to my sky box Technika lcd19-907 hd tv
you shouldn't have to tune the tv, simply plug 1 end of the yellow RCA lead into the yellow AV1 input usually located at the rear of the TV, & plug the other end into the TV output located at the rear of the my sky box. Then select AV1 on your tv. Or better still if you have the HD cable plug it in & select HD channel on your tv no tuning necessary
Mar 12, 2010 | Televison & Video
Have lost the link from sky+ to a second tv which was tuned to sky via channel 5 and majic eye on annolog since re tuning i cannot receive sky on second tv
Hello K Agate,
In the main room where the Sky + is locate. With the sky remote press the following.
Services.
0,1,select
4 (rf)
Ensure that the RF power to set to on, and take a mental note of the channel number the RF is set to. I normally set this to 38 it is upto you.
Now check that the coax lead that links the sky+ box to the 2nd room is plugged into RF out 2 on the back of the sky+ box.
Now go into the other room and make sure that there is a red LED light on your magic eye. If there is then great. If not there may be a fault with you eye. A good way to check this would be to connect it straight into the back of you Sky+ RF OUT 2 port. This would also check to see if there is any fault with the coax cable feeding the other room.
Assuming that there is a Red LED light on the eye when its plugged into the back of the TV in the other room (not the one with the sky box in), This means that there is power getting to it from the Sky + box.
Put your sky box on the TV GUIDE screen. This will make tuning it in a lot easier.
in the other room with your tv remote press the following
Channel 6 or which ever number you want it on.(analogue)
then MENU on the remote.
Go to MANUAL STORE
Then if you go down to where it give you a C ** number just type in what you retrieved from the sky RF menu.
That should bring your sky up then all you need to do now is STORE.
That should be you all sorted out now.
Hope all goes well. If so then please leave a Thumbs up
Cheers Little Dish Fitter.
Oct 21, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Problems turning up my sky remote on a technika tv
It depends which model of Technika TV you have. Visit here....
http://www.skymediauk.co.uk/oneforall.php
for some of them.
Feb 02, 2009 | One For All URC 7740 Remote Control
Technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Dec 14, 2008 | Televison & Video
Hi.
3)
Chris.
Jan 30, 2008 | Televison & Video
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Electro Med Services...
