Question about GE Washing Machines
During a spin cycle what would cause the basket to be out of balance on every washload, even when there is not a balance issue. Basket acts loose and bangs against inside of machine
    Scholar:
  • 61 Answers
Sounds like your bearings are excessively worn, open the machine door and hold the drum (stainless steel bit) try to lift this up if it moves freely without the tub moving (outer bit usually plastic or steel without holes) your bearings are gone. or the drum has broken off the wields that hold it to the shaft.
its sometimes cheaper to buy a new machine than repair the bearings and if the drum is loose it will eventually break something inside.
Posted on Jul 22, 2009
My cabrio will not spin or complete a wash cycle. Acts like iit's unbalanced even when empty. Keep getting an F51 error code
it is most likely a bad center bearing. Was it loud when it sup last? If it was then the bearings are going bad. If not spin the tub by hand and see if its stuck if it is work it back and forth and see if you can break it free. That is still a bad bearing. Also try spinning the basket by hand as fast as you can and see if the bearing sound like they are grinding or smooth. If the bearing seem ok then push down on the tub ring and try to push the tub and basket down it should take quite a bit a pressure to push the tub down is its easy and you can bounce the tub up and down it the washer like a basket ball then you need new support rod they keep the tub stable during spin and when the springs on these go bad they allow the tub to bounce during spin and that causes the unit to go out of balance and stops spinning.
Dec 23, 2016 | Washing Machines
Was told by tech at Equator Co. to take a coat hanger down the dryer vent to clean out lint caught inbetween inner drum and outer drum since unit is about 12 years old. Coat hanger caught on something and...
ur counter balance weights or damper rods damaged
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Another noise issue can arise from a worn SNUBBER RING on some washers that have a snubber like some Maytags, if u notice tiny pc's of white/grey shavings on the floor or around the bottom washer area? A sign of bad snubber. When removing to replace be careful as the spring underneath is pressure loaded.
A very similiar sound can be produced when the belt is worn but the difference is that a snubber noise can be produced during the spin cycle or when the cycle has finished and the spin tub is coasting to a stop. A worn belt noise can only be produced while the motor is actively engaged in spinning the spin tub. If it is discovered that the belt is worn and the base has black, shredded belt residue then it may not necessary to clean it out (belt residue generally will not cause a problem with the snubber). It will be necessary however, to find the cause of the belt failure.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
GRINDING NOISES:
The plastic drive is known as a splutch (splined clutch). One problem with these washers has been loosening of the nut that locks the pulley to the agitator input shaft. If it gets loose, the pulley drops and the teeth no longer have good contact with the teeth of the splutch basket drive gear in spin mode. The solution is application of blue locktite to the threads of the input shaft. There have also been a lot of failures of the actuator that operates the cam ring of the splutch which raises and lowers the basket drive gear. It is raised for agitate mode and lowered for spin. There is a spring between the basket drive gear and the gearcase housing that maintains pressure on the basket drive gear. There are cams on the cam ring that ride up and down on cams in the splutch cam (housing) as it is rotated by the actuator thus raising and lowering the basket drive gear. The gearcase has a planetary gear set in it.
Feb 21, 2011 | Equator EZ 1500 Front Load Washer / Dryer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Spin basket weld gone causing loud knocking on spin cycle
front load washers are a great inovation into our modern society that being said they are a delicate balance of moving parts the main bearing plays a very important roll in keeping the machine balanced during the spin cycle I wouldn,t do one without the other . you're absolutly right too much $$ for a 4 year old machine call Electrolux plead your case and see if the will dicount the price of a new macine at least the value of the basket Good Luck
Oct 09, 2009 | Frigidaire GLTF1670A Front Load Washer
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II spin cycle not functioning correctly
It sound like the basket is out of balance. When it spins open the lid and see if the basket is moving side to side and back to back. If so look under the deck and see if there is springs or rubber ties attached to the basket.
Jan 19, 2009 | Whirlpool LSQ9665JT
Kenmore mdl 10022622100 goes out of balance
to cause unit to go off balance taking in fact that you put clothes in washer even...check your counter balance spring it hold the tub to base at rear of unit,,,and check your balance ring at the top of your wash basket its fill with water if cracked will cause this problem,,
Dec 24, 2008 | Kenmore 22422 Top Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
May 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle
This is a repeat, but maybe the same result.  Remove the front cover (usually two clips between the top and the front, move it around) and check each of the springs that hold the unit to the base.  Have found that just one spring would cause a out-of-balance condition.  When you open the lid, does the basket seem to be leaning one way or the other?  If so, look on the side that shows more than the other.  Also, reach in and grab the inner basket to see if it seems loose.  Have had the basket drive mount break halfway through and caused it to roll really bad.  Let me know what you find out, or if you need futher help.  Jim
Oct 15, 2007 | Maytag Performa PAV2200
Washing Machines Logo
194 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
