Some machines used a variable speed slow down process to avoid clothing damage, this removes the items from the outside of the drum where if the clothing was left for a length of time after the cycle has finished it could damage the fibres, this way the clothing is also easier to remove from the machine and promotes airflow over the items
the plastic pieces are from the friction of the metal spinning onto the white plastic, Part cost about 187 but I am thinking of just ditching this crappy washing machine, something is always going wrong. call me 3616432681
I removed the bottom panel under the door and drained the the tub. There is a white filter housing that unscrews, but you need to have towels handy to catch the water that comes out. The machine appeared to work after that but it would'nt drain and it turns out that the humming noise was coming from the drain pump connected to the filter. I ordered a new drain pump assembly, which should be easy to replace since it is located at the front of the washing machine.
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Hi if your beko 1000 spin washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
I am a recently retired appliance engineer of 20 years
sounds like the dreaded drum bearings, to check, switch off and open the door and try to move the inner chromed drum in the direction it should not go (pull towards you with your hand near the rim edge just behind the door seal) (and not too much force)if there is any play movement or it rattles then yes its confirmed, if the back of the machine is removed you may also notice brown rust water marks coming from the center rear of the drum just behind the center of the pulley
always work with safety with the plug removed, if i have helped please rate me, and if i am correct (sorry) could be an expensive repair
