Question about Ricoh SP C220N Aficio Laser Printer
Client has an SP C220, called us in to look at it. I'm an HP/Lexmark tech, not Ricoph. All three color toner cartridge lights are flashing -- not the replace toner led, just the toner indicators. It's is HIGHLY unlikely that all three cartridges would be "nearly out" as the status monitor says - it's a fairly new printer - so we suspect something else is wrong, but I cannot locate a service manual. Any Rico techs out there that can lend a hand?
  • 68 Answers
You can remove the toner cartridges and clean the end condition sensors mounted on the back of the cartridge with IPA if that doesnt work there has been issues with bad cartridges and also poor sensor connections on the td board in the printer
Posted on Sep 16, 2009
What do the flashing light mean on a lexmark E260D. please help
We would like to know more about the flashing lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
For us to give the common light sequences, please provide us information which light is flashing on the printer.
For further assistance, please call Lexmark Technical Support.
Jun 24, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
The printer toner light is continuously flashing even after putting in a new cartridge
After installing a new cartridge and the blinking light is on Toner Low, it means that the photoconductor is almost full and should be replaced soon. Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, replace the photoconductor kit.
Jun 14, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
How do i install a toner chip on my hp Cp2025
TONER CHIP on CP2025 printer:
This resource may help
http://resources.lasertekservices.com/hp-smart-chips-overriding-this-lockout-mechanism-with-reset-chips/
Gives types of chips to use, sales in USA, and certain things to take note of.
The toner reset chip replaces the original HP ID chip and is designed to be used only on refilled HP cartridges.
It is not recommended to force toner cartridges to run on empty, as this can cause damage to both the printer and the toner cartridge.
The reset chips are dedicated to one color only, so that user can not swap toners.
As for actual physical installation, just push the new ID chip in until it clicks into place. The correctly manufactured ones should be a snug fit.
I have seen techs using a drop of contact glue behind the chip-board to secure it.
Copper pads face outwards towards matching printer pins.
See photo for polarity 'square' pad.
My printer is Samsung, not HP, so your toner cartridge may be a different shape.
Nov 07, 2009 | HP Color LaserJet 2550n printer + HP Color...
About Nashuatec Aficio SP 3200SF question
You could try going into the sp modes and check sp 5052-1 this is for independent toner check if the toner cartridge was checked by the copier as empty and you refilled it the machines check of the chip still senses it empty by turning this off it could reset it for you .. I have had some mixed results sometimes it works only occasional failure.. Hope it helps Good Luck A
Jul 03, 2009 | Ricoh Office Equipment & Supplies
After refilling the cartridge the toner low red light is still flashing. How to stop the flashing light?
Did you remove the plastic tab from the toner cartridge?
It would not be the first time I have been called to a faulty printer to find the cartridge had not been correctly installed.
You say in your post that you refilled the toner. Did you replace the whole cartridge or pour toner into the machine?
Every machine has different toner have you checked that it is the correct type?
Also some cartridges have a chip embedded that tells the machine that it has been replaced it is possible that this has failed either in the cartridge or within the machine.
Jul 03, 2009 | Ricoh Multifunctional SP 3200SF...
Flashing Lights
From the User Guide:
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
If you don't have a User Guide click on the link below and save it for future reference.
2550n User Guide
If this solution has been helpful, please rate it. Thanks!
Jul 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Printer Color problems..
Seriously, buy a new printer. Companies sell toner, not printers! The printer is basically a "freebie" and is a marketing vehicle to sell toner. I tossed my C510 into the dumpster. It had four new toner cartridges. System diagnostics said that everything was at 95% or better. The printer had about 1600 prints on it. The first set of toner cartridges (full at purchase!) printed great. Then, I got dotted lines on clean prints. Or, I would get washed out, yellow tinted print and often, there was no black print. I called a printer repair shop and they laughed and told me to chuck the printer - they were suprised it lasted through the first set of cartridges. Lexmark literally "ignored me to death."
I will NEVER buy another Lexmark. The Brother and HP color lazers are probably the best bet. I have two HP B&W's that are paper pumps - an old 4V and a 6MP. The sad part is that I paid a bit more for the Lexmark than the competing HP. You live and then you learn!
Feb 25, 2008 | Lexmark C510 Laser Printer
Color missing
hello, goto advanced properties of the printer and see can you run a maintaince on it, this usually fix's the fault... let me know how you get on...
Feb 19, 2008 | Lexmark C510n Laser Printer
Ricoh SP C220N Aficio Laser Printer Logo
358 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
