Question about KitchenAid 24 in. KUDP02SRSS Stainless Steel Built-in Dishwasher
My Kitchenaid dishwasher is stuck on the pre-wash cycle
Model # kudn230ywh The dishwasher seems to be stuck on the pre-wash cycle. After hour of running, it still has remained in the same cycle. Any suggestions? Thanks, Paul Morin
  • 185 Answers
SOURCE: Noisy Dishwasher
has there been any hard objects such as fruit seeds nuts egg shells ect. is it doing it in all the cycles
Posted on Mar 28, 2008
IFIXALL
  • 868 Answers
SOURCE: Hotpoint dishwasher stuck on DEMO program
I f you have warranty on this please call them, you have a defective D/W.Unless there is no charge for repairs ,don't spend a dollar on what is going to be a on going problem ahead.To explain how to fix this is what the manufacturer should have done in the factory and not made 1 dollar off of this defective D/W until it proved this to be ready .What has happened to Quality Control ? Does it no longer matter ? Very sorry ,you should seek a refund ASAP.
Posted on Jun 23, 2008
  • 3 Answers
SOURCE: whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Posted on Feb 01, 2009
  • 2976 Answers
SOURCE: My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
Posted on Apr 06, 2009
  • 3 Answers
SOURCE: My normal cycle and cancel button lights are
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Posted on Apr 27, 2009
Kitchenaid dishwasher stuck on wash cycle
I'd you wish to get some details then check the following link.
http://electro-medical.blogspot.com/
Jul 20, 2016 | KitchenAid Dishwashers
Fisher washer stays on clen for over 3 hours
"Fisher washer stays on clen for over 3 hours" ???
I think you mean the "Dishwasher stays in the clean cycle for over 3 hours", right? First question is "What cycle?" If it's the Pots and Pans cycle, or "Pro-wash cycle" , or "Normal cycle with extra wash heat or sani-rinse options selected, then yes, this is normal! A Normal cycle (without added heat) will take about 2 hours. And a short or quick or 1-hour cycle will take less.
Sep 25, 2014 | KitchenAid Dishwashers
KITCHENAID DISHWASHER STUCK IN WASH CYCLE
It can be the issue with defective float switch. The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. One more thing, if your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Jan 16, 2013 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
My Kitchenaid dishwasher seems to be stuck on the wash cycle for over an hour. How to I fix this?
check to see if you don't have it on an extended wash cycle setting. After that, check to see if the dial is stuck.
Oct 05, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
The wash cycles go on for 2 - 4 hours.
I know is sounds strange, but on a typical Kitchen Aid dishwasher, cycles can go longer because the the dishwasher is waiting for the water be raised to the proper temperature, especially during a hot rinse cycle.
Checking that the heating element is working would be the first thing to check.
If the heating element is working, the probable cause is a failed console (which controls the logic/programming of the dishwasher.)
Good Luck!
Apr 03, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Dishwasher runs for a long time
Water pre-heating
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Nov 12, 2008 | Kenmore 24 in. 17362 / 17364 / 17369...
Cycle runs for 2-3 or more hours
If your dishwasher's cycle times are too long, check these: Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
Cycle not completing f the cycle doesn't complete, check these:
Oct 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Open Questions:
See all KitchenAid 24 in. KUDP02SRSS Stainless Steel Questions
KitchenAid 24 in. KUDP02SRSS Stainless Steel Built-in Dishwasher Logo
151 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
