Question about Dryers
I have an electric dryer, Model # is FE01442CESO, and it will shut itself off, with the start and control button blinking. It isn't getting hot air either.
  • 3,600 Answers
Try reseting the breaker first then if it does not work you have a burnt out heater element the blinking light is telling you that you havea problem.
Posted on Jul 22, 2009
Dryer will not start
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not start. I also see that when you press the start button, the lights above the Control button blink and your dryer beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer will not start: when I hit the start button, dryer beeps and lights blink above Control button
-Best Regards-
WP
GEW9878PW! electric dryer, evidently it isn't going into cool down mode
On the late models with electronic controls you either have a bad control OR a bad thermistor. The thermister mounts on the blower housing and the control measure the resistance drop on it as them clothes get dryer. That along with a pair of sensors that detect moisture inside the drum. As the clothes get dryer the less moisture is sensed until the control advances over to cooldown and finally off. So if the thermister is not working correct the temp would be off. The control is way more money than the thermister. I would clean it up first and make sure no air restrictions are causing overheating.
SERVICE MANUAL FOR DUET DRYER IF ON MY MANUAL PAGE AND FREE
Sep 30, 2012 | Whirlpool GEW9878LW Electric Dryer
My dryer is getting so hot that it is shutting itself off mid cycle. I can restart but it only runs a short time....gets really hot and shuts off again!!
Check your entire vent tubing from the outside vent to the line coming out of the back of the dryer.
Overheating indicates low air discharge flow. The air in the dryer must move out quickly so the heat doesn't build up too much.
Try that & post back.
Gary
Sep 15, 2011 | Kenmore 600 6965 Electric Dryer
Dryer shuts off when it gets hot but restarts
1.Remove your exhaust duck on the back of the dryer and clean it.
2.Make sure your exhaust going to the outside vent isn,t clog.
3.Check thermostat.
Mar 07, 2010 | Dryers
Whirlpool duet electric dryer doesn't always start and shuts off
Have you cleaned the exit hose thoroughly? Pulled the exhaust line and cleaned?
Thermostat controls heat. There is also a motor centrifugal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement. The element has a contact in the 'timer' circuit too.
It is possible that your element has failed also.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Sep 01, 2009 | Whirlpool LER4634J Electric Dryer
Electric dryer shutting off
most likely cause is the air duct is blocked with lint, some always gets past the screen and builts up in the exhaoust line. not enough air flow, the air gets hotter than normal and trips the over temperature cutout.
for most dryers
clear the fan, and exhaust ducting all the way to the wall, and the outside vent hood, of lint
Sep 22, 2008 | Whirlpool LER4634J Electric Dryer
My dryer smells hot and shuts off it is a Maytag model LDE8406ACE
This happens when the dryer gets too hot and a thermal breaker (or thermal fuse) kicks in. The most likely problem is that the exhaust vent for the dryer is plugged up with lint either within the dryer itself or in the part that is in your wall and exits someplace outside (could be as far as the roof). When the hot air can't escape the dryer overheats and shuts itself off to prevent a fire.
Sep 22, 2008 | Maytag Dryers
Dryers Logo
105 people viewed this question
Top Dryers Experts
